wat would cause a ks .......
Old Sep 6, 2005 | 11:15 AM
randy021186's Avatar
what would cause a knock sensor code to turn on every 150-200 miles? i thought if a knock sensor is bad it the code should always be there, right?
Old Sep 6, 2005 | 11:22 AM
njmodi's Avatar
Do I get a tax break?
Is that the only code that is being reported? Is the CEL on?
Old Sep 6, 2005 | 11:27 AM
nosispower's Avatar
Are you using premium?
Old Sep 6, 2005 | 11:33 AM
MaximaSE96's Avatar
Maxima Owner
not necessarily.....it could go off and on....if there are no other codes i would say replace ur KS.....but if u have an 02 sensor code i would do that first then see if u get ir KS code back
Old Sep 6, 2005 | 11:41 AM
its just a knock sensor code......and 0705 (annoying evap system)....i did the ohm test and it reads 550, oh btw Premium all the way, thats why i am broke now ..lol
Old Sep 6, 2005 | 11:50 AM
njmodi's Avatar
Fix the Evap system code first. Then worry about the KS.
Old Sep 6, 2005 | 11:54 AM
the evap code was there forever, the valve in the back is bad
Old Sep 6, 2005 | 11:58 AM
njmodi's Avatar
If the KS code only started showing up recently, then it's likely you have a bad KS. I would still recommend fixing the EVAP code before replacing the KS. As you probably know, the KS code is known to show up as a dummy code with a variety of other legitimate failures (O2, misfires, etc.).
Old Sep 6, 2005 | 02:22 PM
Garrick's Avatar
I agree with njmodi everyone seems to have knock sensor problem. Replace it and reset the ECU and you'll be good to go.
Old Sep 6, 2005 | 02:25 PM
Prophecy1's Avatar
Other problems trip the KS.
Fix your other issues or take it to a nissan tech to hook it to a machine to tell u exactly what it is.
Proph
FlaMark
Aug 20, 2015 12:17 PM
Amendemula
Dec 31, 2001 05:15 PM
LucentAUTO
Aug 21, 2001 08:43 AM
RBa
Feb 2, 2001 10:46 PM
