Reasons for weak idle....
Old Sep 6, 2005 | 06:18 PM
TheMax95's Avatar
My 96 5spd has been idling like shyte for a long time now and it's only getting worse. It actually stalled the other day when i was coming to a stop.
recently i've performed the following maintenence procedures on my car:
coolant flush/fresh coolant - car overheated
oil change
plugs
Any ideas?
-Paul
Old Sep 6, 2005 | 06:20 PM
Zack342's Avatar
start looking for vacuum leaks, clean throttle body.
Old Sep 6, 2005 | 06:25 PM
MDeezy's Avatar
cleaning IACV. It has bad idle all the time or at a specific time?
Old Sep 8, 2005 | 12:03 PM
TheMax95's Avatar
It has bad idle only when I put the car in Neutral and let the rpms fall normally. or when I am slowing to a stop in gear and press the clutch right before I stop to put in Neutral.
I'll try the IACV but I regularly clean the tb anyway. Thanks.
-Paul
Old Sep 8, 2005 | 03:02 PM
MDeezy's Avatar
Sounds like the TPS going bad.
Old Sep 8, 2005 | 04:48 PM
vortechpower's Avatar
check your intake manifold gasket. Its a few $ from the dealer.
Old Sep 8, 2005 | 05:06 PM
ImmaSquashYou's Avatar
could be bad fuel injectors?? maybe changing the fuel ffilter will help also...if you haven't done that already
Old Sep 9, 2005 | 11:04 PM
TheMax95's Avatar
so...iacv,fuel injectors, intake manifold gasket, fuel filter, tps.....hmmmm I don't know what to do.
Old Sep 9, 2005 | 11:23 PM
matty's Avatar
Start with the cheap things...Clean IACV, TB with one can of Gumout T/B Cleaner $3.00 (NOT Carb cleaner)..take off the IACV and clean it really well...Change the Fuel filter ($12.00) because its a common maintance item anyway...All that can be had at Strauss Auto on Hamburg Turnpike..that should fix the problem
If you havent messed with the Manifold gasket recently, thats probably fine...and the injectors will effect idle but not really a dipping idle and recovering sometimes...sounds like an AIR problem
-matt
Old Sep 13, 2005 | 08:57 PM
TheMax95's Avatar
-matt
thnx Matty, wow you became alot more knowledgeable than the last time I actually searched this board ( 1yr). btw thats a compliment. I'm not bashing on how you used to be. Thanks again I know exactly where that Strauss is-pretty far down Hamburg but they do carry a wide range of parts.
-Paul
spencerwh1
Jun 30, 2016 05:44 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
homewrecker
Sep 24, 2015 07:01 PM
homewrecker
Sep 23, 2015 03:41 AM
