help, my car wont start.
Old Sep 11, 2005 | 12:39 PM
outsider's Avatar
heres the story,
drove to kfc and parked my car and then went inside to get something to eat.
after i finishing eating, i came back and i start the car normal, the first time i started the car, it started fine but 2 second later the car just die.
so i tried again, the second time i started the car the car die again.
the third time i started my car, all the car do now is crank.
what could be the problems?
i changed cam shaft sensors, no change.
the owner manual states, when the key is in the 3rd position"on" the security light should not stay a constant red.
as of now, that light is staying lit.
the book states if this happen, then my car immoblizer unit have malfunction. wtf does that mean?
i have a aftermarket viper alarm in there already though.
any help would be apperciated
thanks in advance
the security light im talkin about is the one immeditly left on the steering column
could it be my starter?
Old Sep 11, 2005 | 04:33 PM
MDeezy's Avatar
immobilizer, does just that immobilizes your car in event of theft. Its odd, I dont have a 99 with the immobilizer but I'm sure if the immobilizer was in effect the car wouldnt crank. Not sure but sound like the immobilizer could be the source.
Old Sep 11, 2005 | 05:05 PM
outsider's Avatar
yea i was secound guess myself about that.
if the immoblizer was some how malfunctioning, i wouldnt have been able to turn my car over the first 2 time.
as someone stated on another forum, ill check for the ecu and ill try to hit the starter agian
Old Sep 11, 2005 | 05:07 PM
shozo_hirono's Avatar
has any1 here had problems with the engine coils or knock sensor?? Ive heard this is a major prob. with 99 maxes
Old Sep 11, 2005 | 05:38 PM
outsider's Avatar
yes, and yes
once i get my car up and running, ill check my possible ks sensor
can someone check if their security light stay lit on the "on" ,"3" position
Old Sep 11, 2005 | 08:00 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
car will still crank if the immobilizer is activated. i believe the NVIS is a one wire sytem on this, and is very easy to bypass.
Old Sep 11, 2005 | 08:03 PM
MDeezy's Avatar
well if thats the case then I'm sure the issue is with his immobilizer.
Old Sep 11, 2005 | 08:33 PM
sodie14's Avatar
yes, as far as my understanding, the immobilizer will allow the car to turn over, but it wont ever fire (either by limiting gas or spark). i am surprised your car started and ran for 2 seconds or so first though...possible fuel pump failure or something simple like that you think?
Old Sep 11, 2005 | 08:55 PM
outsider's Avatar
how would i bypass this wired?
since my security light is a solid red, then i belive its the dumbass immoblizer
Old Sep 12, 2005 | 09:50 AM
sxymax
try this
try looking under the hood and take the fuse out for the factory alarm
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
N2deep
Aug 16, 2015 08:30 PM
Balkins
Aug 12, 2015 06:39 AM
