aftermarket horn q
Old Sep 13, 2005 | 03:43 PM
Dman832's Avatar
aftermarket horn q
Does anyone with an aftermarket horn (like hella supertone) have them mounted in a place where they can get wet? Because I have mostly seen people mount them right in the front pointing out from behind the grill, but in the warnings on the package for the horns, it says to not let them get wet.... any thoughts?
Old Sep 13, 2005 | 04:22 PM
matty's Avatar
I have Hella and put one poiting forward and no problems in 4 years...
They are red and looked retarted when I installed them...I painted the one that pointed forward BLACK..and fixed that
-matt
Old Sep 14, 2005 | 09:59 AM
Dman832's Avatar
ok, thanks. yeah, the red looks kinda crappy, I might paint mine too.
Old Sep 14, 2005 | 10:01 AM
DigitalTexan2u's Avatar
Mine have been behind my grill pointing outward for over 3 years...no problems at all!
Old Sep 14, 2005 | 10:05 AM
86maxima96's Avatar
I Broke OT
i thin the red will look sweet. i ordered mine a while ago and got them shipped after I went to college, so i'll have to wait till break. but anyway, the stock one is mounted right up there in the front, so why would this be any worse?
Old Sep 14, 2005 | 10:16 AM
Dman832's Avatar
maybe stock is in a different place on our cars...my stock horn is on passenger side facing the engine near one of the mounts. Anyway, I will mount mine soon, if the red looks bad I'll paint'em.
Old Sep 14, 2005 | 10:32 AM
86maxima96's Avatar
I Broke OT
uhh, look for the other one. there should be two horns; that's how the harmonic tone is created. both at different Mhz.
Old Sep 14, 2005 | 11:13 AM
Dman832's Avatar
O! I knew there was another horn somewhere, but couldn't find it, I thought I checked there for it too! ok then...behind the grill they go...
o, and I think it is just Hz not MHz
Old Sep 14, 2005 | 01:12 PM
meanbean's Avatar
You can disregard that warning in this case. Mine are fully exposed to the elements with no problems.
Old Sep 14, 2005 | 01:56 PM
sunten1
Yea my setup is just like meanbean's setup. Its behind the grill. But I have the SE Grill so you really can't see it that much
Old Sep 14, 2005 | 08:17 PM
Dman832's Avatar
excellent, thanks guys. I'm gonna mount them this weekend.
Old Sep 14, 2005 | 08:23 PM
matty's Avatar
You can mount one in the stock location, over by the radator overflow bottle, with no problem...I have my blower in that spot so I moved it underneath the wheel well.
I have one up front and one in the wheel well
-matt
Old Sep 14, 2005 | 09:23 PM
86maxima96's Avatar
I Broke OT
I wish that I had a blower that got in my way...that would be a great problem to have. poo.
I plan to mount them exactly like meanbean
meanbean: how did you do that exactly? the right is obvious, but the left? did you just rig up some small steel extender or what?
Old Sep 14, 2005 | 10:26 PM
Dman832's Avatar
yeah, there are worse problems to have!
Old Sep 15, 2005 | 05:02 AM
meanbean's Avatar
There should already be a existing hole on the left just like the right side. The Hella Supertone horns should come with the steel extenders you speak of so there is no need to rig anything up.
Old Nov 24, 2005 | 09:14 AM
86maxima96's Avatar
I Broke OT
alright, so i finally took the Hella horns out of the box. how exactly did you guys install these? i'm confused what the small plug is for and what you had to ground. can anyone just explain how they installed their Hellas? the more detailed, the better as i'm pretty much a noob when it comes to wiring.
Old Nov 24, 2005 | 09:45 AM
MaDMvD's Avatar
Can anyone post a sound clip of this setup? Thanks!
chisam14
Nov 6, 2018 08:56 PM
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
