Friends car has problems
Old Sep 13, 2005 | 06:20 PM
lanky2882's Avatar
My friends max every now and then when he goes to start it, it will try and turn over you can hear it cranking but it wont start. If it sits for 10-15 min then it will start. Happens almost everyday now. Weather or temperature dont seem to effect anything what do you think could be possibly wrong?
Old Sep 13, 2005 | 06:55 PM
killerVQ30DE's Avatar
ECTS - Engine coolant temp sensor - check the stickies for diagnostic info
Old Sep 13, 2005 | 07:18 PM
Danielson2881's Avatar
Also check the Start Signal
Old Sep 13, 2005 | 07:31 PM
MDeezy's Avatar
dry starter
Old Sep 13, 2005 | 09:15 PM
lanky2882's Avatar
what does a dry starter mean?
Old Sep 13, 2005 | 10:04 PM
Supermax95's Avatar
means you need a new one.....but all of the above are possibilities dont go out and buy a new starter unless you know its the problem.
Old Sep 13, 2005 | 10:16 PM
texasluva's Avatar
Mine did the same thing.. Change the PCV Valve. That is you problem!!
Old Sep 14, 2005 | 04:53 AM
MDeezy's Avatar
Dry starter means the greese that is normally inside the starter and keeps it lubricated and spinning freely is drying up. More cranks give more heat to the starter and greese gets thinnner when it gets warmer so it helps the starter spinn fast enough to crank.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
Ray229Harris
Sep 16, 2015 08:16 PM
yat70458
Aug 3, 2015 01:16 PM
