Squeeky noise
Old Sep 14, 2005 | 01:25 PM
Bourne's Avatar
Squeeky noise
The past couple of weeks I've started noticing a squeeky noise coming from my front left wheel whenever I turn left (whether it's cranking the wheel all the way, or just merging into the left lane). I was wondering if that was enough info for someone to know what it probably is because I couldn't figure it out if I tried. I just wanted to ask on here before I take it into a mechanic and pay money just for them to check it out. Thanks fellus!
Old Sep 14, 2005 | 02:44 PM
zander's Avatar
CV or a bearing would be my guess. Does it also do it at higher speeds? When my bearing went bad it would give like a high pitched hum at freeway speeds. Or it could be a bushing? Good luck man!
Old Sep 14, 2005 | 03:41 PM
Bourne's Avatar
Yeah when I was hauling up the onramp I noticed it when I got on and merged from the right lane to the left, I was doing 75-80mph.
Old Sep 14, 2005 | 05:24 PM
vanjoydi'smaxs's Avatar
yo my passanger tire is making the same noise
Old Sep 14, 2005 | 05:25 PM
but my only does it when i'm going slow and bout 2 turn
Old Sep 14, 2005 | 07:08 PM
zander's Avatar
Yeah Ill guess bearing, but I might be wrong. That same bearing went bad on mine not to long ago. vanjoyd, are you breaking? or just coasting around the corner?
Old Sep 14, 2005 | 08:26 PM
bhmax16's Avatar
Any chance you can get a soundclip? I work in a shop and can likely diagnose it for you if I can hear it
Old Sep 14, 2005 | 08:59 PM
nycspudz03's Avatar
are you talkin about the wheel bearing???
Old Sep 15, 2005 | 09:51 PM
M_oz. 555's Avatar
if it does it when you hit bumps too it could be your sway bar pins. Had the same problem fixed about 3 months ago.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
