Hood lifter holder supporter thingie... CF hood owners plz help
Old Sep 17, 2005 | 04:02 PM
kormax97
I installed my carbon fiber hood and took the struts that hold the hood open off. I want to get those lifting stick thing that I can use to hold the hood open when I need to. Anyone have idea on what I can use? And no, I will not use 2x4s.
Old Sep 17, 2005 | 04:51 PM
njmodi's Avatar
Do I get a tax break?
Get some worn out hood-lifts - they'll work great on the CF hood - and won't be too strong. I'm sure there are people out there who have some worn ones laying around.
O/wise go to a boneyard and pick up one of the hose hood-holder metal rods off any car basically and find a way to mount it onto the max.
Old Sep 17, 2005 | 07:48 PM
Dubbya's Avatar
VK56 Inside
I am using worn out hood struts. They will need to hold an OEM Hood up for a few minutes and then give to work fine with the CF Hood. I bought them off an .org member. Just post up in the f/s section. I tried using a stick from a different car, but was unsatisfied with the results.
Old Sep 17, 2005 | 07:59 PM
DrTySOUFMaX23's Avatar
baseball bat..
Old Sep 17, 2005 | 10:26 PM
Saddles's Avatar
use your dome
Old Sep 18, 2005 | 07:11 AM
RA030726's Avatar
I'm nutty for Nissans
i have been using a pole/handle to a broom ;(
Old Sep 18, 2005 | 10:35 AM
Linkage23's Avatar
CF fishing pole insert....Walmart has them for like $15....
Old Sep 18, 2005 | 10:59 AM
007max's Avatar
great idea, i think i'll do that when i get my hood
mbsup:
Old Sep 18, 2005 | 01:13 PM
sullivs's Avatar
Go to a junk yard and find a metal rod off of the models that do not use the strut shocks. See how it mounts, most of the time the entire assembly bolts on. You can cut and bend it to fit yours. Don't forget to take the rubber part that the rod snaps in when the hood is closed, so it won't rattle around.
Old Sep 18, 2005 | 02:02 PM
93Miata's Avatar
Yup, half worn stockers work great
Old Sep 18, 2005 | 08:08 PM
kormax97
Thanks for the ideas.. I'm gona look into that cf fishing pole insert and check out a junk yard and see what I can find.
Old Sep 26, 2005 | 05:19 PM
tuner001's Avatar
i love my worn out hood struts... they always seem to fail just as i get my head under the hood
Old Sep 26, 2005 | 05:30 PM
96blackmaxSE's Avatar
boost me.....
lol....join the club,
kormax97 I have an offer for you man....check your PM
Old Sep 26, 2005 | 08:28 PM
MDeezy's Avatar
I have regular full strength hood struts, and their working just lovely.
Old Sep 26, 2005 | 09:41 PM
Flava_24/7's Avatar
Boosted Panda
Hood struts is the way to go.
I tried using just a thin rod which wasnt good with wind.
Im now using an old hood support rod from another car I picked up during a yard run that has a hook on the end. I have it to where it hooks on the upper hood latch.
That way it supports the hood plus holds onto it.
The hood strut is the cleanest look though.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
