camber plates for H & R's??
I am finally going to be installing the H&R's wth the Illuminas. I plan on replacing the lower arms/ball joints, spring plates, control arm bushings and sway bar bushings and be done with front end work for many miles to come. With the H&R lowering, will I need to buy camber adjustment plates ahead of time or just wait to see if alignment will stay within factory specs ??? I guess I could go ahead and buy them so I have them, if needed but this project is getting $$$$+. Peoples experience/input with this application is greatly appreciated!!!!!
Camber Plates are about $400 last time I saw. Maybe you meant camber bolts, for an H$R drop you shouldnt need it. I'd drop it and then get an alignment, if they cant get it into spec, dont pay, buy bolts install and go back.
knight_yyz
11-01-2015 01:34 PM
