where to get rpm signal?
Old Sep 21, 2005 | 11:47 PM
joosdawg's Avatar
dont hate but ive seen like 10 differnt posts but no one says what to tap for a rpm source that is the best. i will take a risk and assume if i take the gauge cluster out and splice into the green wires screw on the back that is a clean rpm signal? or should i splice somwhere else? just need to know and im sick of looking for the answer lol -Ryan
Old Sep 21, 2005 | 11:54 PM
nonspin
Don't those big tachs tie in somewhere in the steering wheel?
I may be wrong, but I thought It was somewhere in the wheel base. 3 wires or something?
Old Sep 21, 2005 | 11:56 PM
joosdawg's Avatar
what? theres three wires on the back of the gauge cluster one red one black and one green obviously red and black have to be power and ground im asking if i can just splice into the green one for a clean rpm source and call it a day
Old Sep 22, 2005 | 01:30 AM
Nismo's Avatar
Easier place is the #1 coil pack. Forgot exactly which color is the signal wire though.
Old Sep 22, 2005 | 01:54 AM
jcy98maxse's Avatar
Turbo is too much fun!
tap it off the ecu so you don't have to run it thru the firewall.
Old Sep 22, 2005 | 07:05 AM
laylow1988's Avatar
use the screw on the back of the guage cluster mannnnn!!!!!
Old Sep 22, 2005 | 10:15 AM
Supermax95's Avatar
Is someone puting in a huge ricey tach!?
Old Sep 22, 2005 | 10:21 AM
joosdawg's Avatar
what r u kidding me its for the tach signal for the rpm switch to install my MEVI fruitcake
Old Sep 22, 2005 | 10:26 AM
1FSTMAX's Avatar
i told you already..
Old Sep 22, 2005 | 10:29 AM
joosdawg's Avatar
yes u did thanks for the answer 1fstmax its all good now also thanks for the picture laylow
Old Sep 22, 2005 | 07:31 PM
Supermax95's Avatar
hey man im just joking with you.....
Old Sep 22, 2005 | 07:35 PM
joosdawg's Avatar
its all good dude you didnt know lol but still a tach in a maxima?.... btw i saw the first guy with the finger
Old Sep 22, 2005 | 07:38 PM
eckohb's Avatar
I already told you where to get your rpm signal from...genius...wisconsin people have no brains i tell ya
Old Sep 22, 2005 | 07:39 PM
joosdawg's Avatar
thats why u go to dave buster
Old Sep 22, 2005 | 07:43 PM
eckohb's Avatar
LOL. I go to Dave to get shti done right the first time. And plus he's really sexy.
Old Sep 22, 2005 | 07:56 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Whatever. Use the ecu wire. I sent Davi that SAFC pinout.
Old Sep 22, 2005 | 07:59 PM
joosdawg's Avatar
i think im actually going to use a coil sense the guy that sold it to me had it on a coil and it worked fine and its a harlan so im trying that first if it doesnt work then ill go into the cabin
Old Sep 22, 2005 | 08:08 PM
eckohb's Avatar
Dude, the ECU wire is SO EASY
Old Sep 22, 2005 | 08:09 PM
joosdawg's Avatar
i dont roll like that player back up, ill hook it then we race for slips right? then we'll see what wire is right go get your 00vi back and lets go at it dude
Old Sep 22, 2005 | 08:11 PM
eckohb's Avatar
If i had my VI, you would be toast. LOL. No low end power loss? Plus mid range and top end gain?
Old Sep 22, 2005 | 08:12 PM
joosdawg's Avatar
lol so what at least i may have a chance at staying even with my ecu foo
Old Sep 22, 2005 | 08:14 PM
slimer's Avatar
Ignitions changes with timing.
Ryan, we already tried to do that earlier today.
Davi, keep call those @sshats until you can get it.
Old Sep 22, 2005 | 08:16 PM
joosdawg's Avatar
so your telling me i have to go to the cabin? why does everyone else with the harlan use a coil then?
Old Sep 22, 2005 | 08:19 PM
slimer's Avatar
Use it, I don't care. It probably won't make a difference.
Old Sep 22, 2005 | 08:21 PM
joosdawg's Avatar
so what happened lastnight how come u died on me on aim?
Old Sep 22, 2005 | 08:24 PM
slimer's Avatar
Laptop Battery > Me
Old Sep 22, 2005 | 08:44 PM
joosdawg's Avatar
weak thats why i have a super duper long cable on mine and roll through the hood with it on wireless
Old Sep 22, 2005 | 09:21 PM
euser985's Avatar
you have an electrical problem, you should run the codes
Old Sep 22, 2005 | 09:23 PM
joosdawg's Avatar
ummmmm
Old Sep 22, 2005 | 09:33 PM
Supermax95's Avatar
i thought it was just a hi, they i realized it was the one that flips you off. All in good fun. and exactly a maxima with a tach was the point of my joke....
Old Oct 3, 2005 | 10:54 PM
joosdawg's Avatar
well ditched the harlan for a summit, still trying to tap the ECU for rpm signal now. i used a quick connect on the Green wire with a white stripe was that right? cause it didnt work on my falty harlan lol. how come in Jimes pinout from his site it says the tachometer wire is Green only not green w/ white stripe? if im right then i should be fine with the summit like that right?
Old Oct 4, 2005 | 08:36 AM
eckohb's Avatar
Right
10char
Old Oct 4, 2005 | 09:25 AM
Flava_24/7's Avatar
Boosted Panda
Why dont you use the TAM screw?
Old Oct 4, 2005 | 09:30 AM
joosdawg's Avatar
idk isnt it better to use the ecu wire? plus i already have the wire tapped. i just want a connection that wont mess up at all -Ryan
Old Oct 4, 2005 | 11:30 AM
Flava_24/7's Avatar
Boosted Panda
It really doesnt matter, The wire you want is white with a green stripe. It's next to a couple purple wires
I have mine wired to the TAM screw.
Old Oct 4, 2005 | 11:37 AM
joosdawg's Avatar
where is that picture from the back of the gauge cluster or the ecu harness? thanks for that pic i guess i have the wrong one lol i have green with a white stripe not the other way woops... -RyAN
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
