High pitch noise drives me insane
Old Oct 2, 2005 | 11:18 AM
lucky_777's Avatar
My Max started making high pitch noise from front that really irritates me. Initially I thought that it was my brakes, they were ready for replacement> I just did the brake job and noise is still there. I know for sure it is not brakes. When I press the brake pedal noise doesn't go away. It is like metal rubs against the metal. Drive axles look fine too. What can it be?
Old Oct 2, 2005 | 12:01 PM
MDeezy's Avatar
Do you hear the noise just when driving straight line, in corners, when accelerating, de-accelerating. Hear it only in drive, gone in neutral . . . need some more info.
Old Oct 2, 2005 | 03:26 PM
lucky_777's Avatar
I can hear it all the time when car moves. Doesn't matter if it is on drive or neutral
Old Oct 2, 2005 | 03:27 PM
Maxi98se's Avatar
Hey lucky im in the same boat as you i thought it was my brakes also i replaced both front and rear rotors and new pads and its still there i think it may be wheel bearings??? Its like a weeeee noise but goes away once im goin faster i can only hear anywhere from between 15-40mph when driving
Old Oct 2, 2005 | 04:00 PM
lucky_777's Avatar
Wheel bearings when go bad make humming noise, this is something else.
Old Oct 2, 2005 | 04:02 PM
Caracicatriz's Avatar
What was that?
I have a small crack in my side-view mirror and it squeals really high pitched. Check for any small cracks/holes on your car.
Old Oct 2, 2005 | 04:23 PM
lucky_777's Avatar
It is clearly metal rubbing to metal sound, I would think that wind sounds a little different. Also I can hear the noise even at low speed.
Old Oct 2, 2005 | 05:46 PM
9378max's Avatar
is the noise still there when you turn on the ac? if it is, then its the alternator. this happened to me.
Old Oct 2, 2005 | 06:01 PM
lucky_777's Avatar
There is absolutely no noise when car is not moving and engine is on. Alternator would make noises all the time.
Old Oct 2, 2005 | 08:25 PM
Maxi98se's Avatar
Anyone else experience this ???
Old Oct 3, 2005 | 06:09 AM
lucky_777's Avatar
Maxi98se, you might be right about the wheel bearing. It is going to be major pain is a$$ to replace it...
Old Oct 3, 2005 | 06:22 AM
ChiTown Max's Avatar
It's wheel bearings. had the same thing, replaced bearings, and it went away. Can't remember exactly, but it was around $110-160 parts/labor at a local muffler shop for me....
Old Oct 3, 2005 | 06:28 AM
njmaxseltd's Avatar
Splash shield hitting the back side of the rotor.
Old Oct 3, 2005 | 07:53 AM
Maxi98se's Avatar
When i get out of work today im gonna raise the front of the max to see if theres any play with the front wheels, it sounds like its coming from the front left wheel....
Old Oct 3, 2005 | 01:20 PM
BlackKnight's Avatar
More likely than anything, you barely bent the shield behind the brake rotors and they are rubbing against them as they turn. I had the same problem. I took a long ratchet extension and pushed on the edges of it through the wheel. The thing you have to make sure of is that when you push on the top, the bottom gets pressed against the rotor, so you have to alternate; same with the side. Just keep moving it around and eventually it will go away. Good luck.
Old Oct 3, 2005 | 03:15 PM
killerVQ30DE's Avatar
For me it turned out to be the clutch on the A/C compressor, the clutch was bugger so wasn't disengaging properly and as the pulley wheel was stickiing out due to bugger a/c clutch it was rubbing on the belts
Old Oct 3, 2005 | 07:44 PM
lucky_777's Avatar
It was a Splash shield. Bent it back a little, problem solved for me.
Old Oct 3, 2005 | 07:47 PM
Glad that worked for you. Another problem solved for no money.
Old Oct 4, 2005 | 03:22 AM
Maxi98se's Avatar
Glad you resolved it lucky i wont be able to check my car out till the weekend been so busy at work lately, hopefully this is my problem too ...
Old Oct 4, 2005 | 05:26 AM
PoKKi's Avatar
I think I might have the same problem. After I step of the brakes at a full stop, when I release it, it makes a weird high pitch "EGRRRR" sound. Once I accelerate, the noise goes away. No idea how to fix it. It makes the car rumble too.
Old Oct 4, 2005 | 11:43 AM
lucky_777's Avatar
I'm a happy camper now, zipping along in silence. Thanks to everyone for help!
lowpost99
Oct 26, 2025 06:53 PM
Maxima.KsA
May 15, 2020 04:14 PM
Maxima30
Sep 7, 2015 06:13 PM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
