Speed Sensor Code
Old Sep 22, 2005 | 02:05 PM
TriniRicanPapi's Avatar
Speed Sensor Code
My check engine light came on for a bad speed sensor. I had the speed sensor changed and the check engine light came on again for the speed sensor code. What else could be causing the speed sensor code to come on other than a bad speed sensor?
Old Sep 22, 2005 | 02:11 PM
njmodi's Avatar
Do I get a tax break?
Apparently a bad instrument cluster (speedo or RPM gauge, I'm not sure which) can also cause that code.
Old Sep 22, 2005 | 02:56 PM
maximazer's Avatar
Did you have any problems with RPM readings?
My RPM gauge fluctuates between 2k and 3k sometime, I was wondering if it has something to do with speed sensor.
Old Sep 22, 2005 | 02:57 PM
njmodi's Avatar
You most likely have a bad gauge. Is the VSS code set in the ECU (i.e. is the CEL lit like in the original posters case?)
Old Sep 22, 2005 | 03:10 PM
maximazer's Avatar
Yes, I had both CEL and VSS code.
Old Sep 22, 2005 | 04:00 PM
yea nissan told me if it wasn't the speed sensor it was the guages. but they wanted to charge 300 dollars. where can i buy those online?
Old Sep 22, 2005 | 04:27 PM
SlackR237's Avatar
Rollin' on 'Caps
TriniRicanPapi, I had/have the same problem, and now I'm thinkin it's my gauge cluster too. Does your cruise control work intermittently? Mine only works like half the time and it's got to be the vehicle speed sensor code because that's the only one that's thrown when I check the codes.
Old Sep 22, 2005 | 04:32 PM
njmodi's Avatar
Did you replace the VSS yet?
Old Sep 22, 2005 | 04:50 PM
i replaced the speed sensor and the code came on within a month after having it replaced
Old Sep 22, 2005 | 04:54 PM
Haibert88's Avatar
I have a stick I30t and I replaced the vehicle speed sensor since my CEL was on with that code, it hasn't came back for the 9,000 miles I have driven since then. However my instrument cluster reading sometimes dies out when I'm going below 30mph, but will jump back up after 30-35mph...that's my cluster though (according to my mech)
Old Sep 22, 2005 | 05:31 PM
maximazer's Avatar
No, I didn't.
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
ballerchris510
Sep 23, 2015 08:46 PM
