help me out with my code.......
Old Sep 22, 2005 | 06:27 PM
97maxxx's Avatar
i have my inspection in 4 days and after clearing this code twice it just comes back the same day-its the 0305 code which says
0305
Diagnostic Trouble Code 0305 points to a problem with the Exhaust Gas Recirculation Temperature Sensor. This sensor is a thermistor (a resistor with a value which varies inversely with temperature). The EGRTS is used by the Engine Control Module to test the EGR system operation. Since the signal from the EGRTS is not used for engine operation your car should run perfectly well despite having the Check Engine Light on.
Possible causes of DTC 0305 include ...
- harness or connectors (The EGRTS circuit is open or shorted)
- bad EGRTS
- malfunction elsewhere in the EGR system
The EGRTS may be tested with an ohmmeter.
- at "D" degrees F the resistance should "R" (in Megohms) should be ...
D = 32, R = 0.68-1.11
D = 122, R = 0.09-0.12
D = 212, R = 0.017-0.024
what exactly is that and where is it? i was thinking it was just bad gas is that possible? what do you all think
Old Sep 22, 2005 | 06:30 PM
njmodi's Avatar
Do I get a tax break?
This an easy one. The EGR temp sensor is located on the EGR guide tube. If you pull the IACV off the car, you'll see the metal EGR guide tube bolted to the back of the plenum. The EGR temp/flow sensor is connected to that metal EGR tube.
In fact, the connector for the EGR flow sensor plugs into the harness on a bracket that is held onto the IACV - i.e. you have to remove that little bracket to get to the 3rd IACV bolt (when you pull the IACV).
I hope that makes sense.
Old Sep 22, 2005 | 06:40 PM
97maxxx's Avatar
nope none at all lol sry would you or anyone be able to like find a pic of an engine bay and just circle the are you are talking about -also where can i buy the part? and how much thanks so much
Old Sep 22, 2005 | 06:47 PM
njmodi's Avatar
Do you know where/what the IACV is?
Do you have a Haynes Manual?
IACV :
EGR tube : near the firewall right under the IACV
The EGR temp sensor is the thing attached to the black wire on the right side of the EGR tube just to the bottom-right of the flange (the sensor has a silver collar)...
If all that still doesn't sense... then I dunno how else to help you
Old Sep 22, 2005 | 06:51 PM
97maxxx's Avatar
nope it all makes sense now thanks but does it need to be replaced and if so where can i get that or can it be cleaned -repaired?
Old Sep 22, 2005 | 06:53 PM
njmodi's Avatar
Most likely replaced. Now that you know what/and where, you can try probe the terminals as suggested to make sure its bad.
Probably a dealer only part - so try any one of the online wholesalers (courtesy, jr nissan, pinnacle, etc.)
Old Sep 23, 2005 | 09:38 AM
97maxxx's Avatar
after i turn the code off it comes back on in about 3 miles -what do you all think it is -the gas or is it actually the sensor? i just cant believe it came back on in 3 miles -any ideas has this ever happened 2 anyone before
Old Sep 23, 2005 | 10:10 AM
97maxxx's Avatar
is thier anything else you guys can thynk of -im kinda ****ed if i cant figure this out 2day b/c my inspection is well 2m now since i have work on sun and i really dont feel like driving around without it inspected-it went on twice once after like 7-8 miles of resetting it and another after like 2-3 miles of resetting it -i checked my gas cap and that seems fine and i always put 93 in so its shouldnt be that and i even threw in a thiing of injectot carb cleaner just to be safe-so i really dont know what it is-should i check the sensor itself ? is it worth it thanks again
Old Sep 23, 2005 | 10:39 AM
njmodi's Avatar
You have to replace the sensor.
Old Oct 10, 2005 | 09:05 PM
SpeedyMaxima's Avatar
I have excat the same problem i reset it after 3,4 miles the Check engine light comes back on i also need help guys i dont know where the sensor located and exact the same code for EGR temp sensor 0305
Thnx STeve
