Replacing O2 Sensors?
Old Sep 23, 2005 | 01:18 PM
Obespalov's Avatar
The two front ones, apparently, code 0503 & 0303.
1. What is the cheapest place to buy? Which brand should I use?
2. How much does it cost for the labor at a shop or stealership?
3. Is it easy to do yourself (my level of competense does not exceed past doing my own oil change)? If so, is there a better writeup (w/ pics) than the one in stickies?
Thank You!!
Old Sep 23, 2005 | 02:14 PM
njmodi's Avatar
Do I get a tax break?
1. oxygensensors.com, bosch OEM equivalents (70 bucks each)
2. probably 1 hour for both sensors (they may not let you provide the parts though)
3. yes, get a Haynes manual for 20 bucks.
Old Sep 23, 2005 | 06:33 PM
i30ds's Avatar
Armed and Dangerous
If you know how to use a ratchet and disconnect connectors then you can change out O2 sensors.
Old Sep 23, 2005 | 08:19 PM
FishyMan's Avatar
where else can i get o2 sensors w/ minimal risks?
also, i have 68k and getting the 0707 the rear. but im thinking bought doing the other 2, or should i just wait for codes??
thanks.
Old Sep 23, 2005 | 08:20 PM
THT's Avatar
THT
Throbbing member
Buy them from oxygensensors.com as suggested. Wait for the codes for the other two and do only the rear for now. Check the stickys for my "how to"
Old Sep 23, 2005 | 08:21 PM
i30ds's Avatar
Armed and Dangerous
thanks.
just do all three... www.oxygensensors.com
Old Sep 23, 2005 | 08:23 PM
FishyMan's Avatar
my money order is MISSING .. been 3-4 weeks, filed a claim w/ usps. i sent it to oxygensensor for the discount too, and its been missing since. i'll see what's up. i've contacted paul and still, no word...
i dont want the run-around. i just need the rear, and want to buy it cheap w/ legit ness...
Old Sep 23, 2005 | 08:34 PM
s0ber's Avatar
I just got 2 brand new bosch universal o2 sensors for $20/ea
Old Sep 23, 2005 | 09:29 PM
konak85's Avatar
where dude?
Old Sep 23, 2005 | 09:39 PM
i30ds's Avatar
Armed and Dangerous
Originally Posted by konak85
where dude?
sober is 80 and never reveals his deals.
Old Sep 23, 2005 | 09:59 PM
FishyMan's Avatar
well if he's legit, can u hook up the OE ones.
Old Sep 24, 2005 | 05:43 AM
njmodi's Avatar
autozone.com - there was a recent thread (in the past two pages I would guess) that with a particular zipcode the sensors come up as 19.99 each (front).
Old Sep 24, 2005 | 08:00 AM
s0ber's Avatar
there u go guys, if it doesn't work for your zipcode try 33174
goto autozone.com and search for a 95 max o2 sensor, the bosch one will be $19.99 if it owrks, its some sort of comp error or something but im not complaining.
Old Sep 24, 2005 | 10:01 AM
Gates's Avatar
The deal that you guys are talking about from autozone.com is only for the front O2 sensors. When I searched for the rear is came up as 59.99. Does anyone know of a really good deal on the rear? My car isn't really running all that great right now and I am just going to go ahead and change out my knock sensor and all 3 O2 sensors. I ordered the front 2 from autozone already and my knock sensor from ebay ($70 look for the thread), but I'm still looking for a deal on the rear O2 sensor. Anything cheaper that $60?
Old Sep 24, 2005 | 10:05 AM
s0ber's Avatar
Put in my area code instead of yours and it will come up as $19.99
Old Sep 24, 2005 | 10:15 AM
njmodi's Avatar
Just to clarify - the deal is for a Bosch Universal sensor... not OEM connector.. so you'll have to splice in your old connector... not a big deal given the great price!!!
Old Sep 24, 2005 | 10:30 AM
djengr's Avatar
ditto, takes about the same amount of time to jack the car up, put the jack stands under it, and find the O2 sensor. Sometimes you might need to get or borrow a sensor socket from autozone.
Old Sep 24, 2005 | 10:37 AM
Gates's Avatar
In the other thread is says that the $19.99 o2 sensor is the front. It gave a similar part number for the rear, but that comes up as $59.99 even under the zip code i used to order the fronts for $19.99. You were able to order the rear sensor for $19.99 too? Or was that just the front?
Old Sep 24, 2005 | 10:56 AM
s0ber's Avatar
just the fronts, the rears dont matter
Old Sep 24, 2005 | 02:00 PM
Gates's Avatar
? The rears don't matter? Should I not worry about replacing the rear sensor? I'd really like to do everything at once so I won't have to worry about anything for a while. I already ordered the knock sensor and the front o2s, but I was looking for a deal on the rear o2.
Old Sep 24, 2005 | 02:14 PM
s0ber's Avatar
Buy a o2 simulator for the rear o2, just to get rid of the CEL.. rear o2 has no affect on performance
Old Sep 29, 2005 | 08:02 PM
nad819's Avatar
don't buy new ones, go to radio shack and sodder in 1.2k ohm 1/2 resistors into the signal line That's how i got rid of my CEL with test pipe and y pipe.
Old Sep 29, 2005 | 08:49 PM
FishyMan's Avatar
isn't the o2 there for a purpose though?? the rear ones i mean. i dont feel good about soldner it.
anybody got a OEM one or something? need one for rear.
Old Sep 30, 2005 | 03:18 AM
THT's Avatar
THT
Throbbing member
The rear serves as a check for the cat but does not affect performance when malfunctioning.
Old Sep 30, 2005 | 09:52 AM
Sy0p's Avatar
a 4th gen maxima has 2 oxygen sensors. one before and one after the catylitic converter right?
s0ber's Avatar
3 o2 sensors...
2 before the cat
Old Sep 30, 2005 | 01:05 PM
THT's Avatar
THT
Throbbing member
97+ CA spec have four.
Old Sep 30, 2005 | 01:46 PM
Maxride99's Avatar
rear 02 sensor is for diagnostics only, dont worry about it guy, that sensor is pointless (check chitlins and haynes manual)
*damn they must have caught it, itsnot coming up anymore even with sobers zip code
Old Sep 30, 2005 | 06:53 PM
FishyMan's Avatar
i see guys.
well i still feel it is there for a purpose don't you think? well if it doesn't i'd still like to replace it.. know any place legit and quick enough?
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
