overheating?
Old Sep 23, 2005 | 01:36 PM
oddball86's Avatar
overheating?
My masima overheated on the way to work 2 sundays ago. Well, rahter was almost at H withthe heater on max and the car not stopped but moving. The radiator fans dont seem to tunr on even when stop and the tmep begins to raise. Any input on how i could fix this would be appreciated. BTW coolant isnt low is like a 1/2 inch below max when all warmed up.
Thanks,
Tyler
Old Sep 23, 2005 | 02:13 PM
Thorby's Avatar
My advice: Overheating an engine can really seriously send it to the junk yard. Don't drive it until you fix it.
Old Sep 23, 2005 | 02:16 PM
njmodi's Avatar
Do I get a tax break?
Figure out why the fan's aren't switching on. If you turn on the A/C (even if the car is cold) the fans should turn on. If the fans don't, then you need to figure out why (fuse, electrical connection, relay etc.). Most likely it's time for a new fan tray.
Old Sep 23, 2005 | 03:12 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
sounds like your cooling fans are bad and need to be replaced. As njmodi said, first check the fuses and wiring for the fans. Could be something as simple as a fuse
Old Sep 25, 2005 | 06:14 PM
oddball86's Avatar
cool thanks for the input i shall investigate furhter tomorrow
Old Sep 25, 2005 | 06:31 PM
djill's Avatar
****, that sux
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
