My woodgrain is peeling.....HELP
so, maybe I'm ****, but a corner of the woodgrain of one of the passenger dash vents is not sticking and the same thing is also happening at the corner of the piece under the guages. Is there an easy fix? would I do harm to heat with a hair dryer and peel it off? I'm not overly impressed with the kit in the first place but the car that came with the kit sucked me in.
Same situation
I think you have the same problem I have. You're talking about the wood dash kit, I assume. In my case, the plastic actually cracked because someone pushed down on it when it was "hardened". Same place as yours, right upper corner just below the dash vents. I posted in the General Forum for ways to get rid of the entire trim cause I'll probably replace it with something else.
And I'm sure heating it wouldn't do any damage because a couple of times when the inside of my Max was extra hot from being in the sun, the plastic was actually flexible like rubber... I just never had any glue around to try and "save" it... So much for that now...
Re: Same situation
I'm having the same problems as both of you and was thinking of getting rid of it and replacing it with something else like aluminum but I was sure of the best way to take it off with out doing damage to the stock trim underneith the woodtrim. I thought of just heating it up too.When it gets hot in my car the pieces are really flexable.
Max99
Max99
2da mizzax
Mar 4, 2007 07:11 PM
