Defibrillators?
Old Sep 30, 2005 | 10:29 AM
  #41
ryant35's Avatar
Originally Posted by Dan
Not true. It is actually current that kills you. If you wire it straight to your heart, a AA battery could kill you.
its not the voltage, its the amps, its less than a single amp, even at low voltage. If you were to wire a bunch of AA batteries, at 1.5 volts each with all of the + sides & - sides togather, not end to end like in most electronics, you will get higher amps. I'm not sure how many milliamps are in each AA but a few of them wired right could stop your heart.
Old Sep 30, 2005 | 02:07 PM
  #42
Garrick's Avatar
This is true. You hear of stun guns with like 100,000 volts. They have a really low current (amps) If those little things had more amps, they would cook you from the inside out.
Old Sep 30, 2005 | 04:09 PM
  #43
PAREDLINE's Avatar
What was his name? You know... Your "girlfriend"
Old Sep 30, 2005 | 04:50 PM
  #44
goldtooth's Avatar
(sucks in air with puckered lips).....damn!
owned. lol jk
Old Sep 30, 2005 | 05:09 PM
  #45
quique's Avatar
you only need about a 100 milliamps to kill a person so it is not very much amperege at all. and the higher the voltage could actually be better for you because it travels on through your skin instead of all your organs. anyway a car battery can kill you.
Old Oct 2, 2005 | 08:24 AM
  #46
ryant35's Avatar
Originally Posted by sean05
i may be dumb but im not that stupid
I came to see my girlfriend a few years ago with my brand new car right off the lot, and I noticed that the battery terminals were loose, so her dad grabbed some channel lock pliers and tried to tighten it. Well... the rubber handles were worn off and the ends so when he turned the pliers down on the + the end contacted the -, just as I opened my mouth to say STOP! he got zapped. and the pliers went flying.
Then I was working at a tire shop few years before that, and I guy with a Vett came in having trouble starting. So I got it up on the lift and noticed that the starter cable directly from the battery was loose. So I grabbed a wrench and went to tighten it up and on the first turn I touched the end of the wrench to the side of the frame and ZAP!!! it startled me and I jumped back and slammed my head on the lift. I could stop shaking for the rest of the night.
Now I take off the neg lead on the battery every time I work on the car. I guess its not that bad reprogramming preset stations...
Moral of the story, sometimes we are that stupid.
Old Oct 2, 2005 | 11:11 AM
  #47
RockfordMax's Avatar
Back from the dead
lol dudes, like 50 milliamps for around 5-10 seconds can shut ur heart down. The current can be 1 volt, or it can be 500,000. If you actually get zapped with 1 amp from either of those, your dead. think of it as basically a pressure washer. you still move all the water, but getting hit in the mouth with a 3500 PSI washer hurts a buttload more than getting trickled on by the garden hose.
Old Oct 2, 2005 | 11:18 PM
  #48
toyick's Avatar
once again..
well once again i am tryen to waste my first 15 messages on useless things and for some odd reason i stopped at this paticalr post...found it to be probally the most humorous one that i had read yet. And its quite odd...but i was in boston a few months ago and i was going threw the train station and low and behold was a sign...i never knew what it was..anyways...here is a pic for the post..
Old Oct 5, 2005 | 06:17 PM
  #49
Garrick's Avatar
lolz yes. CLEAR!!!
Old Oct 5, 2005 | 08:38 PM
  #50
mad-max98's Avatar
those are AED, THEY are universal and not advanced at all almost anybody can use them because they tell you what to do,,,,,,,,,this thread is fu<kin' hillarious my laugh for the day
