Help Me! Serious Problem?
Old Oct 2, 2005 | 02:32 PM
slammed's Avatar
Hello all
Im having a problem with my Maxima.
When I press down the gas pedal, all the way...the car revs but it does not accelerate at all
its not the transmission because it shifts gears without a problem at normal driving speeds and I have made it to 70 mph without an issue (shifted fine at normal speeds)
this problem occurs only when I step on the gas (floor it)....it doesnt matter what gear Im in...when I step on it, it revs and doesnt accelerate at all
what is the problem? how much will it run me?
any help will be appreciated.
thanks
Old Oct 2, 2005 | 02:33 PM
turbo
Manual or auto?
Old Oct 2, 2005 | 02:37 PM
slammed's Avatar
automatic
Old Oct 2, 2005 | 02:38 PM
turbo
How did you get up to 70MPH without stepping on the gas?
Old Oct 2, 2005 | 02:40 PM
PandaXpress's Avatar
yeah how do you?
Old Oct 2, 2005 | 02:42 PM
slammed's Avatar
WHen I press the gas all the way down.....it doesnt go anywhere
When I drive normally it shifts fine...I just cant accelerate as fast as I should
ex: When Im driving to merge unto the highway, I press the gas all the way down (pedal to the floor)...it wont acccelerate
killerVQ30DE's Avatar
He means if he FLOORS it the car doesn't go.. if he gradually accelerates normally it does
I say Kickdown switch?
Old Oct 2, 2005 | 02:44 PM
slammed's Avatar
thank you...I guess I shouldve been more specific
my mechanic said that it might be the gas filter or TPS sensor....I just wanted a second opinion from you guys
Old Oct 2, 2005 | 02:47 PM
slammed's Avatar
BTW...there were no codes pulled when scanned
Old Oct 2, 2005 | 02:51 PM
2 Da Max's Avatar
does the car rev up? did you check your throttle cables?
Old Oct 2, 2005 | 02:54 PM
slammed's Avatar
hey man whats up
(I was expecting you to come to our car audio meet a few weeks ago)
anyway, yes the car revs up fine....it just doesnt accelerate.
Ill check the cables
thanks
Old Oct 2, 2005 | 03:08 PM
Black Maxima
Automatic when floored = downshifts into a lower gear, revs that gear out and continues to the higher gear. POS AUTO
Old Oct 2, 2005 | 03:38 PM
maximagxe1997's Avatar
Similar Issue - RESOLVED
I had a similar issue with my 97 GXE.
What was happening was, regular driving, shifting up etc. all worked just fine and I did not notice any flare-up of the RPM. But when I was driving at say 75-80MPH at 5th gear and floored the gas pedal, instead of the car accelerating, I would see the tachometer flare up, settle down a few hundred RPM's and THAN it would have a gradual accleration. Almost like as if the acceleration was not linear.
BTW - my vehicle already had 134,000 miles on stock clutch and it was good time replace the clutch. So I had a clutch job done and also replaced the flywheel with Nissan OEM parts.
Everthing is fine. My vehicle is completely stock.
Old Oct 2, 2005 | 04:06 PM
he has a Auto
Hmmm still thinking its the kickdown switch.. haven't got my haynes here to check the real detail.
Unclejunebug
Apr 2, 2016 05:42 AM
02PearlSE
Feb 1, 2016 12:37 AM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
