P1320 after Compression Check
Old Oct 3, 2005 | 05:52 PM
whiteNJI30's Avatar
Hello everyone. Last night I did a compression check because I was afraid I had a blown headgasket, turns out everything is just fine all cylinders were at 180. However, once I put everything back together and started it up the SES came on and a scan put out P1320. I read up on this code and found it had to do with the coilpacks. So today I reset the ECU took it for a spin and it never came back on. So my question is simply this, is there cause for concern that a coilpack is bad or did this come up because of the compression check? Some posts about this code said that the coilpack(s) still may be bad even if the SES doesn't come back on after clearing it.
Old Oct 3, 2005 | 06:43 PM
njmodi's Avatar
Do I get a tax break?
Perhaps you didn't quite seat one of the coils back down properly. I wouldn't worry about it until you either get the code again or feel the engine misfiring.
Just double check that you plugged the coil pack harness connectors in all the way - you should hear a clear click for each one.
Old Oct 3, 2005 | 08:30 PM
MDeezy's Avatar
aw11power
Oct 10, 2021 04:57 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
