shakey/lumpy start up?
Old Oct 5, 2005 | 06:55 AM
cardana24's Avatar
Blown
On my 95 GXE when I crank the car it starts up fine, but once it is running it runs very lumpy, and it shakes. If you try to drive the car while it is doing this, it jolts and runs crappy. It usually takes about 20-30 seconds for this problem to clear up, and then the car runs as smooth as a top. My CEL light is not working so I am not sure if I am throwing any codes since I have not had a chance to run to Auto Zone to have the codes scanned. Any ideas on this? Its worse when the engine is cold, but it does it all the time. At first I thought it may have been from using a fram oil filter so I switched back to Nissan and still I have the same problem. I do not think it is an oil problem because the oil light goes off as soon as I crank the car. Any help guys?
Old Oct 5, 2005 | 07:01 AM
MDeezy's Avatar
I'd get the codes pulled that willn be able to tell you exactly whats wrong better than our speculation.
Old Oct 5, 2005 | 07:22 AM
cardana24's Avatar
Blown
yeah I am going to do that, but I will take some speculation for now
Old Oct 5, 2005 | 07:27 AM
95jr6708's Avatar
had a relatively similar problem with cold starts only though. But it turned out to be the fuel pump...it took a few cranks but it would run fine after about 10 seconds. good luck.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
