Door panel INSERTS>>
Old Oct 10, 2005 | 07:27 PM
MaxMateo5's Avatar
My inserts were aftermarket and came off.. need to replace them... How do the stock inserts attach??? Anybody have a set...
Any other options for me to cover these panels without paying alot to do them in black vinyl or leather? thanks
Old Oct 10, 2005 | 07:59 PM
95MaxRB26-DETT's Avatar
as far as how do the factory inserts attach... You know where the small slits are? On the oem inserts, there are small medal bendable clips. you take off the door panel, insert the inserts, and bend the clamps down so it can grab and hold the pannel. Other than that, dont know. you could get some from a yard I'm sure. do you have a "pull-a-part" there? stuff is pertty cheap at those...
Old Oct 10, 2005 | 08:00 PM
ThisMaxIsTight's Avatar
what the heck do you mean your inserts are aftermarket and came off? ... how did they come off?? ... maybe you should try re-gluing them ... you can buy black vinyl by the yard and just fabricate the insert, this will look cheap though.... or you can buy oem leather inserts and glue them on and itll look banging
Old Oct 10, 2005 | 08:08 PM
lol, they don't glue on.. They clamp on..
Old Oct 10, 2005 | 08:58 PM
PandaXpress's Avatar
find the clips in your door panels (you will have to take them off)...assuming they came lose o fcourse...reattach them to the door insert and there then back on the door panel...another option is always 3M gluing that bish to the insert part on the door panel with the higher 3M 90 glue and there you go..let it thoroughly dry though if you plan to do it that way.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
