RPM's going lower and lower
Old Oct 11, 2005 | 08:18 AM
ajsilvaoc's Avatar
Hey guys, need help with a little problem that starting to develope on a 96 GLE. About a month ago I started to nothice that my idle RPM's are starting to drop. Stitting at a light with my foot on the brake and the transmission in any gear I am at the 500 RPM mark. Put the car in park and the RPMs go up to 700. With the lower RPMs the car idles a little rough. any ideas of what might be happening? This is a totally stock 96 with 70,000 mile on it. So that takes out any mod problems.
thanks
AJ
Old Oct 11, 2005 | 10:25 AM
latinmaxima's Avatar
your cat might be backed up or yu may want to run some fuel injector cleaner.
Old Oct 11, 2005 | 10:46 AM
tavarish's Avatar
fwd gone rwd cr00
that's normal, the engine should idle on an auto at around 700 without load, and drop to 5-600 under load. If you want it a little higher, just adjust the screw on your throttle body.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
