Not getting power from cigarette lighter outlet
Old Oct 14, 2005 | 08:17 AM
krammer's Avatar
Folks,
Checked the FAQ, but could not find anything. I am not getting any power from my 12V cigarette lighter outlet. It was working fine before. Is there a fuse or something I need to look at? Please point me in the right direction.
Thanks in Advance.
Old Oct 14, 2005 | 08:34 AM
95jr6708's Avatar
Have you made sure it is plugged in? Yes there is a fuse but if it were blown other things in the cab would not work to.
Old Oct 14, 2005 | 08:42 AM
Bobo's Avatar
You shouldn't smoke in the Maxima! If you're concerned about a radar detector or something else, look into it, if not who cares?
My cigarette lighter has never worked.
Old Oct 14, 2005 | 08:46 AM
mendon99's Avatar
tastey wheat
prolly came unplugged or something, take your shifter trim off, look around behind there
Old Oct 14, 2005 | 08:49 AM
chillin014's Avatar
Happened to me too, other thigns in the cabin did not malfunction.only the cig lighter.
Check fuses. Get a fuse checker and figure it out
Old Oct 14, 2005 | 09:11 AM
krammer's Avatar
Oh no! I don't smoke! I was using the outlet to charge my mobile and use the inverter for my laptop. One fine day, it stopped working. Mobile charger and the inverter is fine because it works fine in my other car.
I will probably nose around and see if there is something loose or if some fuse is blown. BTW, everything else in the cab works fine.
Old Oct 14, 2005 | 09:15 AM
98maximagle's Avatar
There should be a guide printed on the door that covers the fuses. if there aren't any blown, then twist the cig lighter to the left and pull gently. There is a wire harness that connects to it, and it possibly could have come undone.
Old Oct 14, 2005 | 09:23 AM
nosispower's Avatar
Probably the fuse. It's in the fuse panel below the cruise control switch and I think it's the 5th one down from the top left.
I lost my lighter and got one from Autozone that probably draws more current, so I have to replace the fuse every month or so.
Old Oct 14, 2005 | 10:18 AM
98MaximaEcstasy's Avatar
Fuse, happen to me and I just put in the spare fuse that comes with it and now it works great!
Old Oct 14, 2005 | 10:52 AM
PandaXpress's Avatar
the way you said that sounds like your trying to sell some kind of drug or something..lol...
Old Oct 14, 2005 | 01:29 PM
THEJEFFERATOR's Avatar
make sure key is on, mine only works that way. if not, check fuse.
Old Oct 14, 2005 | 03:50 PM
hahah yea, the maxima drug
Old Oct 14, 2005 | 06:43 PM
95GoldSE's Avatar
yeah my cig lighter is out too
Old Oct 14, 2005 | 07:25 PM
Sounbwoy's Avatar
Originally Posted by krammer
Folks,
Thanks in Advance.
I have the same issue in my car, but the fuse is fine. Found out that the prongs where the fuse connects is kind of loose. Pressing on the fuse itself brings power back.
Old Oct 17, 2005 | 07:30 AM
krammer's Avatar
Thanks a lot everyone. It turned out to be pretty simple to fix. There is a sicker behind the cabin fuse panel cover which has all the details about which fuse is for what. There is one separately for the cigarette lighter. I think it is the 6th fuse from the top on the left most column. And yes, there was a spare 15A fuse available also.
Thanks!
Old Oct 17, 2005 | 12:09 PM
Maximasevspec's Avatar
Ye myn dosent work too.. i tested hte wires behind the plug for power and the is 12v power and also my fuse is fine but the plug is dead... im guessing its the plug it self it died after i used a power invertor for my laptop
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
