Check engine light: Evap canister code
Old Oct 14, 2005 | 10:03 AM
hollaatchaboi's Avatar
I have an evap canister code and the shop i took it to said there are too many components to know exactly which part is triggering it. If i take it to Nissan, they will probably void my extended warranty because of my y-pipe and muffler. What can i do to find out what the problem is? What thing i did notice is that the car burns a lot of gas.
Old Oct 14, 2005 | 12:46 PM
alpicone's Avatar
Which code are you getting? Number?
Old Oct 14, 2005 | 01:15 PM
kormax97
If you have a front strut tower bar, check your EVAP (little round plastic thing I can't remember what it's called right now) does not have a break right under the FSTB and by the throttle body.
Old Oct 14, 2005 | 01:22 PM
I got the code 01 11 and meineke got the code P1440.
Could my y pipe have an effect on it?
Old Oct 14, 2005 | 01:23 PM
I don't have a front strut bar
Old Oct 14, 2005 | 02:27 PM
tuner001's Avatar
that would be a really good reason as to why my EVAP codes keep coming and going all the time i hate that
Old Oct 14, 2005 | 03:00 PM
CalsonicSE's Avatar
0111 is the EVAP system "jackpot" code meaning it points or one or more components or the EVAP system system.
Possible causes include (BUT NOT LIMITED TO)...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
Also, a y-pipe will not trigger the 0111 code.
Old Oct 14, 2005 | 04:32 PM
but will this make me burn more gas? And do i have to take it to Nissan to find out which component is failing?
Old Oct 14, 2005 | 05:15 PM
CalsonicSE's Avatar
You can test the various components yourself. You'll find all the info (location of the various components, testing procedures, etc.) in a factory service manual. Hayne's repair guide will cover some but definitely not everything. Good luck.
But for now, reset the CEL, and see if it comes on again.
CorollaULEV
30
Aug 9, 2021 08:11 PM
lux97Max
19
Aug 27, 2015 07:48 PM
bassmann
Aug 13, 2015 10:13 PM
