ABS light problem
Old Oct 14, 2005 | 10:42 AM
lordaphex's Avatar
ABS light problem
i got another problem...my ABS light is on. The ABS therfore does not work. Every once in a while (every few days or week) the light will go off for a minute or two and the ABS works, but the light goes back on so they stop working again. this leads me to believe that I have no idea whats wrong.
Old Oct 14, 2005 | 11:35 AM
mtrai760's Avatar
'Trynna' is not a word
Okay... So what sort of help do you need? The ABS system can generate codes, have you tried getting them read to see what is wrong? that would be the first step.
Old Oct 14, 2005 | 12:37 PM
njmaxseltd's Avatar
It's most likely a wheel speed sensor. Pull the codes to find out which one it is and replace it.
Old Oct 14, 2005 | 09:06 PM
lordaphex's Avatar
hmm. nobody knew about reading codes for the ABS system. Not even the Nissan dealer mechanics. Is it just like a code reader for the check engine light? go in the same place?
Old Oct 14, 2005 | 09:22 PM
mtrai760's Avatar
No, there is a procedure in the FSM, haynes, and chiltons manuals for pulling the abs code. There is a connector you have to ground out, and the ABS light should flash any codes stored. I don't have my 4th gen manual anymore, and I have not picked one up yet for the new car, so I cannot look up the procedure for you. I'm not suprised the nissan tech was confused, most of them are.
Old Oct 16, 2005 | 12:35 PM
lordaphex's Avatar
thanks alot, ill try that
AnsonJ
Jun 2, 2017 01:35 PM
VerzOphion
Aug 28, 2015 07:57 PM
2k0to2k3
Aug 18, 2015 09:59 AM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
