Max's with subwoofers please help
Old Oct 15, 2005 | 11:26 PM
1NICEMAX's Avatar
I've tried posting this in the "audio/electronics" forum but no one seems to post anything back. I just want a simple set-up with: 1 or 2 10"subs and an amp. Nothing fancy. NOW: I don't think our bose HU has a power out for subs. What do I need to have everything working properly?
Old Oct 15, 2005 | 11:34 PM
AGRECORDS
hey it's kinda late... that might be why know one posted back...but anyway im all aftermarket so i cant help sorry...just keep asking you'll get an answer!
Old Oct 15, 2005 | 11:40 PM
1NICEMAX's Avatar
nah I asked last week. i'm not THAT impatient lol
Old Oct 15, 2005 | 11:42 PM
MaximaSpd85's Avatar
You have to use a hi/lo converter, tap into a speaker. i have mine tapped into my rear deck speaker.
Old Oct 16, 2005 | 12:20 AM
Fr33way™'s Avatar
Wild for Width
You can have factory Bose with an amp and subs.
Old Oct 16, 2005 | 01:36 AM
InsneDrmr's Avatar
You need a line output converter, aka Hi/Lo converter. This takes low level outputs and puts them into RCAs so that you can properly connect it to an amp. It also allows you to adjust the volume of the output. You can go directly from your rear speakers, BUT be sure NOT to tap into the wires to the amps. Doing this will fry your converter. Ill check tomorrow on which color wires are what and let you know.
I had this myself, but soon changed out the HU and speaks as well. I wanted a more "perfect" sound.
Old Oct 16, 2005 | 01:44 AM
maximazation's Avatar
I tapped into the rear speakers, a positive from the left and a negative from the right to balance everything out, and hooked it up to an aftermarket amp and subs, sounds great, everyone who rides in my car always complimets how clean the bass sounds and didn't lose much sounds at all from the rear speakers. The only downside is that the spoiler vibrates when the bass hits, I guess all Maxima onwers with subs and a spoiler have this problem.
Old Oct 17, 2005 | 12:54 PM
1NICEMAX's Avatar
now someone else is telling me that I need this PAC AOEM-NIS2. i'm confused.
Old Oct 17, 2005 | 01:41 PM
BigLou93SE's Avatar
Isn't that for when you want to add an aftermarket headunit to your factory bose speakers?
Old Oct 17, 2005 | 01:48 PM
latinmaxima's Avatar
yes that makes sure your bose amps keep power with the aftermarket head unit. hi/lo converter on my car and it sounds fine. i actually tapped min into the speaker wires behind the head unit. you have the amp output if you go straight off the rear speakers so it is louder and crisper but also distorts easier at higher volume. just depends if you keep it cranked or like it at a decent level.
Old Oct 17, 2005 | 01:59 PM
Haibert88's Avatar
I have a bazooka in the back hooked up with one of those hi/lo converters...I got it all installed for $60 and they did a super clean job from wires to mounting etc etc. but this was at a swap meet in LA
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
