Servicing
Old May 30, 2001 | 08:13 PM
JMKeehn's Avatar
I had someone tell me that when I go to replace spark plugs, wires, etc. I need to take it to a dealership because they have to tune the electronics of the car as well. I am more than capable of handling the servicing part, but will the dealership really mess with the computer and such? It really doesn't make a whole lot of sense to me. Anyone able to help me out?
Old May 30, 2001 | 11:45 PM
justmax's Avatar
that person doesn't know what they're talking about...
1. There are no "electronics" to tune. The ECU is self-learning, so even if new plugs needed it, the ECU would figure it out by itself.
2. Gen4 and 5 Max's don't have spark plug wires.
Replace your spark plugs with confidence.
Old May 31, 2001 | 05:35 AM
deezo's Avatar
Be sure to use ratchets whenever possible. The Philips screws (which hold in the coils for each spark) will strip if they haven't been moved in a while.
Old May 31, 2001 | 06:49 AM
Daniel B. Martin's Avatar
That "someone" is misinformed. You can do this work yourself.
Routine servicing of cars is simpler and easier than ever. No more points and condenser. No more ignition timing adjustment. No more carburetor adjustments. No more chassis lubrication.
Old May 31, 2001 | 06:54 AM
JMKeehn's Avatar
I appreciate your guys help.
Old May 31, 2001 | 08:29 AM
Eric L.'s Avatar
No wires or electronics to worry about. I suggest you stick with the stock NGK Platinums.
Old May 31, 2001 | 08:34 AM
deezo's Avatar
Yes.
I have the Bosch +4's and they don't feel the same.
Old May 31, 2001 | 12:17 PM
JMKeehn's Avatar
I was considering getting Bosch +4. Thanks again for the advice. I suppose I'll be going back to the same manufacturer. Is there anything else y'all think I should be aware of or might want to look into while I'm doind all of this?
Old May 31, 2001 | 01:32 PM
deezo's Avatar
Depending on when you want to do the replacement, you should buy the NGK Platnium plugs from www.courtesyparts.com
They sell them for much less than most dealers and auto stores.
my03maxima
Jul 28, 2024 07:40 AM
Excalibur23
Oct 13, 2015 04:33 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max8
Sep 22, 2015 02:53 PM
Pixel
Sep 15, 2015 05:53 AM
