need help with radiator
Old Oct 20, 2005 | 09:15 AM
MaximaRacer_95's Avatar
does anybody have a write up for changing a radiator..and also if u could include the tools i would need..thanks
Old Oct 20, 2005 | 11:06 AM
njmodi's Avatar
Do I get a tax break?
Look at the alternator replacement how-to at www.motorvate.ca. You have to remove/unbolt the radiator to remove the alternator - so everything you need should be there.
Old Oct 20, 2005 | 08:57 PM
90EightSE's Avatar
I see you have a '95 but according to my '98 Service Manual page LC-15:
1. Remove under cover.
2. Drain coolant from radiator.
3. Disconnect radiator upper and lower hoses.
4. Remove radiator shroud.
5. Remove A/T oil cooler hoses. (A/T models only)
6. Disconnect resevoir tank hose.
7. Remove radiator mounting bracket.
8. Remove radiator.
9. After repairing or replacing radiator, install any part removed in reverse order of removal.
There is no mention of Special Service Tools to remove the radiator. There is emphasis when refilling the radiator to not allow coolant to contact the drive belts.
Old Oct 20, 2005 | 10:16 PM
thanks alot
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
