Clutch fluid leak
Old Oct 21, 2005 | 04:27 AM
maxedout95's Avatar
Clutch fluid leak
I have a stick shift and I've had the leak for about a year and now it really is bad and I think I messed up my clutch and possibly synchros cuz im not able to shift only when I turn off the car. My question is where do you think the leak might be up where the master is or down by the clutch what is the most frequent spot.
Thanx
Old Oct 21, 2005 | 08:06 AM
GodFather's Avatar
Made in Taiwan
i think the most frequent spot comes from a bad drive shaft seal. lot's of us had the same problems, and it's a costy bittch to fix... good luck.
Old Oct 21, 2005 | 08:13 AM
Bobo's Avatar
He is talking about clutch fluid, not transaxle gear oil!
I suspect you either have to replace the clutch receptacle because it is leaking, or else it is the slave cylinder. However, problems with a slave cylinder do not tend to drag on as long as yours has, so it could be something else.
Old Oct 21, 2005 | 09:06 AM
97SEdriver's Avatar
this place is dead
I don't have shifting problems, but I also have a leak, I tend to stay on top of the clutch fluid though. A slow leak is most likely what, a slave cylinder? I don't see anything unusual up at the receptacle.
Old Oct 21, 2005 | 10:16 AM
maxedout95's Avatar
you think it might be the master cylinder the one on the firewall.
Does anyone know how long it takes to replace a clutch?
Thanx
Old Oct 21, 2005 | 12:53 PM
96ItaliaSE's Avatar
il massimi bassi
i had a slow clutch luid leak in my 96 speed. Not in the transmission but where I would put brake fluid.
It turned out to be the rubber clutch line on the transmission that feed the clutch slave cyinder . Motorvate.Ca explains that this is a common failure..if your have ever replaced your clutch or tranny that rubber line should be replaced, if not you will get a slow leak. I replaced my lines with SS one on the group deal.
I reccomend you replaced the piece no matter what...you get a better clutch feel and it will most likely solve your problem.
Old Oct 21, 2005 | 01:01 PM
cardana24's Avatar
Blown
a lot of us have had this same problem. I replaced my slave cylinder and that did not fix it so, I replaced the hose and copper washers that were going to the slave cylinder and this fixed the problem. Get someone to push your clutch in while you are looking at the slave cylinder and the hose and try to pin point the leak. If it were me I would just replace the slave and the hose and washers. Goodluck.
Old Oct 21, 2005 | 02:16 PM
97SEdriver's Avatar
this place is dead
cardana24,
A while back I posted a thread about replacing the rear valve gasket, after I replaced it I couldn't find the thread to thank anyone. So thanks, it really wasn't that bad except for the stealership giving me the wrong gasket. My oil light is still coming on at idle sometimes, but I think that's because my idle is a little low.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
