Huge Problem!!!
Old Oct 22, 2005 | 03:33 PM
4thgenx42's Avatar
Huge Problem!!!
Well i just replaced my 5spd. tranny w/ a new one from the dealership. Well I got my car back 10/18/05. I have a huge problem. Before my car use to start a little rough, my battery sucked. I bought a new one cause the old died out from the car not being turned on for about 2 weeks. I put the new battery in. Now when i go to start the car I have to keep the key to start for about 15 secs. If this doesnt work i do it again and then the car cranks.
Does anyone know what is causing this? I thought maybe a bad fuel filter or spark plugs . But i channged those yesterday, and it didnt work. The starter sounds fine. Tomorrow I will be doing the fuel pump just cause i think that might be it. Im afraid if i dont fix this soon my starter is just going to fry... Help Please!!!
Old Oct 22, 2005 | 04:15 PM
f550maranello2's Avatar
bad grounds... i had the same problem after i swaped the motor in my old car.... just clean up the grounds
Old Oct 23, 2005 | 07:56 PM
4thgenx42's Avatar
Where else are the grounds on out cars, besides the one on the block?
Old Oct 24, 2005 | 07:55 AM
tomservo291's Avatar
You mean it does *nothing* for 15 secs before it cranks?
I had similar problems for the last month or so.. cleaned up my terminals and connections, still the same, and then it started cranking over slowly sometimes sounding like the battery was dying (but it wasn't the battery) and eventually my starter died about a week ago.
I had to get a push start (5 speed) to get home and replace the starter in the morning.
But if the starter is working fine once it turns over, then its probably a connection or maybe even the solenoid?
Old Oct 24, 2005 | 04:04 PM
4thgenx42's Avatar
Yeah thats my problem it turns turns turns, then after about 15 secs itll crank over and start. Then the car drives as if it had no problems...
Old Oct 24, 2005 | 04:06 PM
kormax97
how do you know your starter is good?... of course it's going to "sound fine" when it starts...
Old Oct 25, 2005 | 06:36 AM
Wait, so it is cranking the engine for a long time (as fast as its supposed to?) and then after ~ 10-15 cranks it starts?
What was happening to me was that *NOTHING* was happening for a long period of time, turn the key and all you got was the accessory power (lights, radio etc) and the starter just laughed at you, until it came to life and started my car; which quickly ended and resulted in a new one...
Old Oct 25, 2005 | 06:57 AM
Ruthless's Avatar
And the starter for the 99 max Se is no where near cheap......
Old Oct 25, 2005 | 07:33 AM
brad kay
mine was doing that ^ and it drew my battery dead a couple of times. It wouldn't hurt to just pull your starter off and take it in to Auto Zone and have them test it to see if its still functioning properly. if nothing else you'll eliminate one area that the problem might be comming from, and you'll probably find its your starter going bad and save yourself draining a battery or two over time.
Old Oct 25, 2005 | 04:11 PM
4thgenx42's Avatar
Thanks guys! Im gonna try the starter...
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
