look at my Xenarc Osram & Philips D2S bulbs (pics)...few questions
Old Oct 23, 2005 | 11:56 AM
kingrukus's Avatar
no more maxima...
Are these Philips D2S bulbs identical (in color?), notice the different #'s on the right side of the bulb.
Also, is there any way to tell their color temp by looking at them?
Are these Xenarc Osram bulbs identical (in color?), notice the different #'s on the 2nd pic.
Look at this spare Philips Bulb I have, notice the part circled in red is very cloudy...is this a sign of anything, or do I have anything to worry about here?
Finally, which pair of bulbs would you go with and why for a retrofit w/ E46 single xenon projectors? Xenarc Osram or Philips?
Old Oct 23, 2005 | 12:04 PM
nismology's Avatar
Normally i'd flame you for making 3 seperate threads that could very easily be condensed into one but i know you've been here a while and know better. Question is.....why?
Old Oct 23, 2005 | 12:05 PM
maximus_96's Avatar
geez why not lump all your hid parts questions into one thread? you can never be sure of the colors unless you are sure they are a matched pair that came out of the same car. the 85122 on the philips and 66040 on the osram means they're 4100k or 4300k. i forget which it was. the other numbers doesn't mean anything of importance to you. philips are suppose to be more white after burn in while the osrams have a slight pink color
Old Oct 23, 2005 | 12:13 PM
kingrukus's Avatar
no more maxima...
Sorry for making 3 seperate threads, but they are 3 different topics.
Old Oct 23, 2005 | 12:46 PM
pmohr's Avatar
No more Maximas...
Even so, they're all about your new HID setup, and as such they can all be condensed into one thread.
As nismology said, you've been here for a while, one would assume you would have seen that multiple threads on the same issue isn't well recieved. Hell, I've seen people banned for less.
Old Oct 23, 2005 | 12:52 PM
coolcatne's Avatar
The greater the number of hours the HID bulb has been used the greater the accumulation of salts in the bulb(reference to the cloudy bulb).
Old Oct 23, 2005 | 01:47 PM
kingrukus's Avatar
no more maxima...
Do you really need to repeat what he has said? Stop posting in my thread. Thanks
Old Oct 23, 2005 | 01:48 PM
kingrukus's Avatar
no more maxima...
Ah that explains that, so Ill be sure to return that bulb then.
Old Oct 23, 2005 | 02:00 PM
njmaxseltd's Avatar
Thats most likely a batch control number. Both bulbs are identical.
Old Oct 23, 2005 | 02:12 PM
Kevlo911's Avatar
Kevlo for President
85122: D2S. Color is bluer white with slight greenish tone.
Old Oct 23, 2005 | 02:16 PM
kingrukus's Avatar
no more maxima...
Does anyone know the exact color temps of the 85122 (ie 4100k or 4300k)?
Additionally does anyone know the exact color temp of the Osram Xenarc 66040?
Old Oct 23, 2005 | 02:21 PM
Kevlo911's Avatar
Kevlo for President
They are 4300K
Philips D2S 85122 bulb 4300K 1pcs
For replacement of: Osram XENARC D2S/D2R, Xenarc 66040 D2S, Xenarc 66050 D2R
Some sites say 4100k
Old Oct 23, 2005 | 02:25 PM
kingrukus's Avatar
no more maxima...
Originally Posted by Kevlo911
They are 4300K
Interesting. I am also hearing that the Osram's have a little more yellow to their light, and once they color shift they go to a white/pinkish color. I think I will stick with the Philips if that is the case.
Old Oct 23, 2005 | 02:28 PM
Kevlo911's Avatar
Kevlo for President
I read that they start out at 4100K and after 200hours of use they switch to 4300ish K.
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
minsbang
Sep 11, 2015 08:48 PM
Johnny9595
Sep 3, 2015 05:18 AM
