Are 4th gen (i.e. 95-99 I30's) VLSD manual trannies prone to having bearing probs?
Old Oct 27, 2005 | 10:23 AM
CalsonicSE's Avatar
My non-VLSD 4th gen tranny is definitely on it's way out. Same probs like many other ppl here have - whining/humming sound in gear and it leaks fluid from the input shaft like no other.
I might be able to get a deal on a VLSD manual tranny from an I30, so I'm wondering if these VLSD trannies are prone to failure as the non-VLSD trannies. Thanks.
Old Oct 27, 2005 | 10:26 AM
Bobo's Avatar
I have a 95SE, 5-speed, with LSD. It is a Canadian model. Apparently they are less prone to the dreaded differential bearing failure. However, I do have a leaky left transmission seal that I should replace.
To date, the car shifts like new and I have had no strange noises whatsoever, albeit the car only has 61,350 mostly highway miles on it.
Old Oct 27, 2005 | 10:32 AM
mtrai760's Avatar
'Trynna' is not a word
As cheap insurance, get the shims checked before you install the new tranny, that should help insure you won't have bearing problems down the road.
Old Oct 27, 2005 | 12:08 PM
Nealoc187's Avatar
SLOW
Yes they suffer from the same input and differential carrier bearing probs as the other trans.
My VLSD trans had the diff bearings replaced and my friend's VLSD trans needed the input shaft bearing replaced.
EDIT: My VLSD trans is a 5th gen VLSD trans however, just remembered you specified 4th gen VLSDs. MikeD's I30 trans that needed the input shaft bearing replaced is 4th gen however.
Matt93SE
May 24, 2019 02:58 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
seesole
Aug 26, 2015 11:22 AM
t6378tp
Aug 24, 2015 07:03 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
