Clucth pedal problems...please help!
Well my clutch pedal will not come all the way up sometimes. Some times it just comes half way and stops there and i have to pull the remadnder distance with my foot back up to the top. What could this be, Slave cylinder?
also my clutch keeps adjusting itself. Sometime the release point will be high and sometimes it will be real low.
PLEASE HELP!
PLEASE HELP!
make sure your fluid level is good. If it isnt then you have a leak somewhere. Either at the SC or MC. In my car it was the MC that creadted the same symptoms that you are describing. Try to see if you can see either one leaking. If you cant I'd bet on the MC.
Also how many miles are on your car?
Originally Posted by ManualMaxima
my car has 140,000. my fluid level in the slave is great. so i do not see leakage anywhere from it. how hard is the MC to replace?
If it is the MC it's not hard to change. The first time I changed one it took 30 minutes because i put it in wrong the first time and had to take it out.
which one is the slave cylinder and which one is the master? which is the one beside the brake booster in the upper driver side fo the firewall? and where is the other one located? thanks alot guys
HerpDerp1919
09-29-2015 02:02 PM
