Intake Question
Old Nov 1, 2005 | 07:26 AM
impliedparadox's Avatar
Intake Question
I am looking on the Cattman Performance website and thinking about getting the JWT POP intake. Will I also need to buy the Billet Aluminum MAF Adapter to fit the POP intake properly? Will this intake add horsepower?
Old Nov 1, 2005 | 07:53 AM
99grnmaxgxe's Avatar
You should check the stickys first. The MAF adapter does come with the intake and it does add high end power but you lose some low end power.
Old Nov 1, 2005 | 10:36 AM
GodStr3ngth
I bought this 97 nissan maxima that got a injen cold air intake. It's built for mid-range power. What does that **** mean "mid-range power" i dont know much bout car technical questions, I just love driving my Maxima, its a fast *** far over all. I like dusting these papis in my area that ride around in there hondas.
Old Nov 1, 2005 | 10:42 AM
GodStrength
that venom module box that cost around 400 dollars, is that worth getting?
Old Nov 1, 2005 | 12:03 PM
Mxrider52's Avatar
I support for what?
It actually a good investment you really dont notice any lose in low range. This will make your car fly
Old Nov 1, 2005 | 01:33 PM
so does this mean I will not see much difference in low RPM accel but will have more power at higher RPM's? or at higher speeds?
Old Nov 1, 2005 | 01:46 PM
JPMax's Avatar
What's next!?..
Best performance increase is from an aftermarket Y pipe.
Old Nov 1, 2005 | 01:50 PM
ok, rather than taking a loss in low end power (which I really do not want), should I go with a combo intake system or modify my airbox (run hose through wheelwell) and add a K&N filter?
Old Nov 1, 2005 | 01:54 PM
MaximaSpd85's Avatar
stock airbox is better overall for performance...if all u want is sound u can modify it with the K&N as u mentioned. If ur looking for power but don't have a y-pipe, get one as JPMax suggested.
Old Nov 1, 2005 | 02:00 PM
ok thanks, I will have to see if i can find $350 for one.
Old Nov 1, 2005 | 02:08 PM
whoaaaa!! I believe Warpspeed is about $160 shipped, Budget is wayyyyy less than that as well. NaplesMaxima just installed OBX headers and y-pipe for less than $350. U can even grab a used one from someone here. if u havent checked out this website, chek it out. it will help u in ur modding tremendously http://maxmods.dyndns.org/
Old Nov 1, 2005 | 02:15 PM
looking at things now, it says Warpspeed is now a bit more expensive, as are many other y-pipes, but nevertheless u can find something for around $200 bucks or even $100 bucks used
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
