5th Gen 6spd in a 4th Gen
Old Nov 1, 2005 | 10:55 AM
96jerzeymax's Avatar
Is it possible? Is it alot harder to do than a 5spd swap?
Old Nov 1, 2005 | 11:55 AM
pmohr's Avatar
No more Maximas...
Appears it isn't so easy - http://forums.maxima.org/showthread....ghlight=6speed
Old Nov 1, 2005 | 12:08 PM
Dubbya's Avatar
VK56 Inside
Not easy at all.
Old Nov 1, 2005 | 12:10 PM
NmexMAX's Avatar
dot dot dot ...
Possible, but not easy, and what are the resons for this being better than the 5MT >>
pissing contest starter
Old Nov 1, 2005 | 12:21 PM
Dubbya's Avatar
VK56 Inside
Thats why I did the VQ35.............
Old Nov 1, 2005 | 12:22 PM
Mxrider52's Avatar
I support for what?
Waste of money
Old Nov 1, 2005 | 12:27 PM
MaxKlinger's Avatar
From what I understand, it requires removing one of the existing transmission mounts and then fabricating and welding a new one for the 6spd. The first five gears are almost the same on the 5MT and the 6MT, the main difference is that the 6MT has an additional overdrive and some extra weight. It really all depends on what your priorities are...for racing, the 5MT is what you'd probably want; for an everyday highway cruiser, you might want the 6MT.
Old Nov 1, 2005 | 12:33 PM
Dubbya's Avatar
VK56 Inside
You also need to swap the ECU.
Old Nov 1, 2005 | 02:53 PM
I only asked b/c I can get one for a little less than the cheapest 5spd I found.
Old Nov 1, 2005 | 04:21 PM
NmexMAX's Avatar
dot dot dot ...
Spend the extra ca$h, or suffer the extra headache
Old Nov 1, 2005 | 04:57 PM
THT's Avatar
THT
Throbbing member
QFT
10char owns me
Old Nov 1, 2005 | 08:13 PM
maxS
6spd hard to swap in... you ppl are wimps no offence... 5spd is old skool, 6th is new age.
Old Nov 1, 2005 | 08:51 PM
NmexMAX's Avatar
dot dot dot ...
New age with more parasitic loss, sloppy shifting and 2 overdrives ...
Old Nov 1, 2005 | 08:53 PM
maxinthamax's Avatar
6 speed is the way to go bro! its like:
"i got a v6 with a 6 speed yo!" thats hot
Old Nov 1, 2005 | 08:56 PM
NmexMAX's Avatar
dot dot dot ...
^^ That was pretty
Old Nov 1, 2005 | 10:10 PM
Dubbya's Avatar
VK56 Inside
Im at a loss for words.
Old Nov 1, 2005 | 10:39 PM
darklegend06's Avatar
I was woundering if it is better to swapping to a VQ35 engine with the 6spd trans from a 2K2 maxima. I'm planning on keeping my car for a LONG time from now.
Old Nov 1, 2005 | 10:59 PM
RastaManMax's Avatar
Why waste all the time and go through all the headaches for such a marginal gain. I don't recall the 6sp Maxima doing much better (if at all), than a similarly equipped Altima 3.5 5sp. Come to think of it, i've seen better times for the Altima if anything.
Old Nov 2, 2005 | 07:08 AM
NmexMAX's Avatar
dot dot dot ...
The only advantage is very very very slight better gas mielage.
Old Nov 2, 2005 | 08:24 AM
Dubbya's Avatar
VK56 Inside
And you will spend more trying to make the tranmission work with your 4th gen than you will save in gas money. /thread
Old Nov 2, 2005 | 08:28 AM
lilaclucymaxima's Avatar
Team Ramrod
Is it better? What do you mean by better? That's a rather vague question. Haven't you read these posts about the 6-speed transmission. Not worth it IMO. Check the all-motor forum for information on the 3.5 swap, if by better you mean more powerful, then sure.
Old Nov 2, 2005 | 03:45 PM
THT's Avatar
THT
Throbbing member
Use the 5spd for slightly more aggressive gearing. If you're feeling ambitious, use 1-3 gears from an 00 Altima for slightly better acceleration at the expense of fuel economy.
Old Nov 3, 2005 | 04:17 AM
MaxKlinger's Avatar
Originally Posted by THT
Use the 5spd for slightly more aggressive gearing. If you're feeling ambitious, use 1-3 gears from an 02 Altima for slightly better acceleration at the expense of fuel economy.
Do they have the same transmission case? Has someone done this, to swap the 1, 2, and 3 gears from an Altima into a Maxima? Does the 2.5S 5-spd Altima and the 3.5SE 5-spd Altima use the same transmission?
Old Nov 3, 2005 | 03:14 PM
THT's Avatar
THT
Throbbing member
Jclaw on this board has done it. I believe the gears came out of a 3.5SE but I could be wrong.
Old Nov 3, 2005 | 03:49 PM
NmexMAX's Avatar
dot dot dot ...
Wasn't it an older generation Altima ... ?
Ah well.... search and thou shall find!
Old Nov 3, 2005 | 04:12 PM
THT's Avatar
THT
Throbbing member
I stand corrected: http://forums.maxima.org/showpost.ph...3&postcount=28
If you're serious about doing this, you might as well bulletproof the gears before you put them in: cryo, shot peen (marginal benefit, these two), and deburr.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
