CV joint pass side
Old Nov 3, 2005 | 02:49 PM
ti2tmax's Avatar
Has his VINs memorized
CV joint pass side
Got the car up on jack,both wheels off the ground (front) and spin one wheel to see if LSD or not... the other wheel doesn't spin at all(this is the same on the other side). I thought because I have non canadian=non LSD the wheels should spin opposite directions? My passenger side outer CV joint has a slice in the boot and there is grease leaking out of it so I plan on getting one to replace it soon. I guess what I'm asking is, is the wheel NOT spinning good normal working condition? or busted up condition... And how long would I be able to go... Maximum I'm willing is til the steering wheel tugs side to side when accelerating.
Old Nov 3, 2005 | 08:23 PM
Black98Max's Avatar
Any idea how i could get the axle out of the Hub? how hard should i hit it with the punch?
Old Nov 4, 2005 | 08:00 AM
stevo936's Avatar
You can get an axle pusher. We use them at work, You screw threw lugs on it and use and impact to push the axle threw. You should be able to borrow one at autozone or someplace.
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Bonka
Sep 14, 2015 11:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
