Has anyone had a Keyless entry remote problem?
Old Nov 4, 2005 | 07:39 PM
gtmuggs's Avatar
Im checking to see if anyone else has had this keyless entry problem, my problem is that my keyless entry worked fine up into a few days ago when i went to use it, it didnt respond so i figure maybe its the battery and change the battery in the remote, but still no response, so i try to reprogram the remote using the guide found in the stickies but it still does not respond so at this point im lost as to what could be causing this!
Old Nov 4, 2005 | 07:56 PM
86maxima96's Avatar
I Broke OT
i had a time when it totally wasn't responding either, but it was just the battery. i changed that an no problems.
that's the only problem i have had.
Old Nov 4, 2005 | 08:14 PM
MDeezy's Avatar
change the battery, maybe it was in your pocket pushed up against something and killed the battery.
Old Nov 4, 2005 | 08:17 PM
chillin014's Avatar
the keyless entry module is in your trunk next to your antenna. i think you have to take out the jack to get to it but i dont remember off the top of my head.
if you can unplug the white plug going to the box and then plug it back in and try again.
this happened to me and it worked instantly i didnt even need to reprogram the remote.
Old Nov 5, 2005 | 10:13 AM
gtmuggs's Avatar
thanks ill be sure to try this
Old Nov 5, 2005 | 10:29 AM
MilesA's Avatar
One of the two original keyless remotes died on me. Tried replacing the battery, but still didn't work. I got a replacement unit on Ebay, put in a fresh battery and reprogrammed it for with my car. Works fine.
Old Nov 5, 2005 | 10:35 AM
pmohr's Avatar
No more Maximas...
You have to pull the trunk liner back right where the jack access panel is to get to the entire unit, though you may be able to just reach in behind the trunk liner to just un/replug the harness. It's not behind the metal trunk panel where the jack and antenna are, but on the other side, 'inside' the trunk. Could've sworn I had a picture...can't seem to find it though.
Old Nov 5, 2005 | 10:38 AM
icedoutmax22
only problem i had is when i had to change the batt in the remote because it was dead other than that nothing wrong.
Old Nov 5, 2005 | 10:48 AM
pmohr's Avatar
No more Maximas...
Mine works intermittently, sometimes I have to press the unlock button multiple times, and long presses before it registers and unlocks the driver's door. Also locking it, I've set off the alarm by accident before trying to lock the doors and setting the alarm, because none of the buttons work 100% of the time.
Actually...the dome light button strangely seems to work perfectly every time, just the trunk, lock, and unlock buttons are fritzy.
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
