Door locks
Old Nov 4, 2005 | 11:10 PM
Car With No Name's Avatar
Door locks
Hi there peeps,
I have a quick question regarding my door locks. I use my key fob almost exclusively and found my door locks needing some lubrication. Driver door lock is not turning at all and passenger door lock is kinda sticky. What lube do you guys use for this?
Old Nov 4, 2005 | 11:17 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Just use some WD-40.
Old Nov 5, 2005 | 05:15 AM
pmohr's Avatar
No more Maximas...
KY seems to work for me.
Actually, I've never seen a door lock cylinder requiring lubrication of any kind on really any of the cars I've used...including an Olds from '89 that extremely rarely had any action with the key.
Do you know that they just need to be lubed up, or have you checked for anything binding or otherwise catching the lock cylinder inside the door?
Old Nov 5, 2005 | 01:15 PM
Well I haven't actually taken anything apart as of yet. I figured I would try the lubricant as my first line of attack...heheh. I was thinking maybe some type of silicone spray or tri-flow or something. I'm thinking it's stuck mainly due to the passenger side appears to be heading in that direction.
Thanks for your replys
Old Nov 5, 2005 | 04:30 PM
DennisMik's Avatar
wd40 like vlasic suggested, but i would follow it with either a silicone or light oil. wd40 penetrates through corrosion but it is not an oil, so it dries out and some sort of lubrication will still be needed.
i use auto trans fluid on many things. it is a thin oil, it has penetrating qualities on rusted bolts and chemicals to prevent buildup. almost as good as 3 in 1 oil.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
