Hum with A/C on?
Old Jun 1, 2001 | 04:32 PM
Ants97SE's Avatar
Anyone else get a very low whining humming sound when you your A/C is on? It disappears when the A/C is shut off. Just wondering if it's normal.
Old Jun 1, 2001 | 04:49 PM
The_quorum's Avatar
yes.
Old Jun 1, 2001 | 07:33 PM
hattyhat's Avatar
I do too.
Old Jun 1, 2001 | 07:37 PM
max808's Avatar
Humming
Mines hum on low speed (level 2). It comes and goes, I think this is normal. Have anyone heard of not to use your AC on level 1 because the cold air pressure can't be released fast enough?
Old Jun 3, 2001 | 07:34 AM
Ants97SE's Avatar
Ok.
Old Jun 3, 2001 | 08:14 AM
justmax's Avatar
where does the hum come from?
Is it under the passenger-side dash and sound like a cricket on speeds 1 & 2 but disappear at 3 & 4? Several other people have had the same problem and the dealer has replaced part of the A/C under the dash (fan I think).
Does it come from the stereo speakers? If so, there is excess noise getting into the stereo from the electrical system. You should check your power and ground connections. I used to use those $20 noise suppressors from radio shack in my first car (an '87 Escort 4-speed manual). This was before I knew a whole lot... I heard noise... add a noise thingy... add an amp... more noise... second noise suppressor... it worked.
Now my Max has 2 amps(400 & 600 watts), an aftermarket deck, CD changer, and ZERO noise.
Old Jun 3, 2001 | 11:37 AM
Ants97SE's Avatar
No it's not speaker noise because I had that before in my previous Maxima. It's like a whine coming from the engine, I'm just guessing it's the way the compressor sounds, just wondering if it was supposed to be that noticable.
Old Jun 5, 2002 | 05:45 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Sorry for bringing this post from the dead, but I want to find out from you or anyone if their AC is still running fine with the compressor "hum". Usually I drive with the music on quite loud so I don't noticed these things, but today I drove with the radio off and heard the strange humming noise. I turned off my AC and the noise went away. I had my compressor replaced with a new one several months ago by the dealer. Is this humming, in fact, "normal"???
Old Jun 5, 2002 | 06:14 PM
max808's Avatar
mines still has the cricket sound on levels 1 and 2 (ac on and off). i think it's the blower motor rubbing against the housing.
Old Jun 5, 2002 | 06:23 PM
VeeQueue's Avatar
My blower doesn't make any cricket sounds. Just the compressor. I believe there is a TSB fix on the blower motor noise.
Old Jun 5, 2002 | 07:41 PM
max808's Avatar
I saw the TSB and bought the part. It made the noise a little more quiet but the noise is still there.
Old Jun 5, 2002 | 08:06 PM
1slowmax's Avatar
Where did you buy "the part" from? I assume you're talking about the blower housing?
Old Jun 6, 2002 | 12:24 AM
max808's Avatar
it was just a part that covers the blower motor cover. it sort of insulates the motor cover. don't buy it, it's not worth it and won't fix your problem.
Old Jun 6, 2002 | 12:21 PM
Yossarian's Avatar
info on that TSB
http://forums.maxima.org/showthread....limate+control
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
Bonka
Sep 14, 2015 11:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
