Who knows stereos?
Old Nov 6, 2005 | 04:03 PM
wayman's Avatar
Who knows stereos?
Here's the situation, repalced my two front speakers a few months ago. Just recently, the two fronts began fading in and out of operation. Sounded like a loose wire but to have both go at the same exact time is very odd. I checked the connections at the head unit and they are good. I've always installed my own stereos in my cars and am sure I connected everything correctly.
When I turn the fade all the way to the front speakers, they work okay. As I slowly bring the fade back to zero, they begin cutting out at about level 10 or so (15 is the highest level). So, the more power I give them through the head unit's fade control, the more likely the fronts work.
Here are the questions:
1. Could this problem be the head unit or is it something else?
2. In an unrelated topic, do Maximas take a certain size power attena or is it a generic size? How hard is it to replace a power antenna? Any good places to find a cheap one?
Any thoughts would be appreciated. Thanks.
Old Nov 6, 2005 | 04:24 PM
2 Da Max's Avatar
sounds like your hu is fawked
what brand hu and speaker?
Old Nov 6, 2005 | 04:57 PM
wayman's Avatar
Pioneer head unit and Kenwood front speakers.
Old Nov 6, 2005 | 05:36 PM
lilaclucymaxima's Avatar
Team Ramrod
The audio/electronics forum people know stereos.
Old Nov 6, 2005 | 06:49 PM
DcMaN's Avatar
you could have the polarity reversed causing the speakers to be out of sync. Check teh connections make sure you have positve and negative hooked correctly.
Old Nov 6, 2005 | 07:35 PM
InsneDrmr's Avatar
Yea it sounds like either a short in your wiring, or you have the polarity backwards. Double check on those and then let us know whats happening.
Im pretty good with stereos...if you cant figure it out..PM me.
Old Nov 6, 2005 | 08:06 PM
Maxride99's Avatar
is/was your max a "bose" edition with the bose sound system? if so and you didnt pull out the amps in the speaker wiring path before you installed everything (or afterwards either way) then those amps would interfere with proper speaker operation.
Old Nov 6, 2005 | 10:57 PM
wayman's Avatar
I should highlight that my system was working perfectly for over 4 months. This problem occured very abruptly and fairly recently. I've installed speakers and head units in several of my other cars and it is highly unlikely that I reversed polarities by accident. I know for sure that the wiring is correct at the head unit where I spliced in the wiring harness.
And no, my car doesn't have the Bose systerm.
Besides polarity, could it be the head unit?
Thanks for everyone's help on this.
Old Nov 7, 2005 | 09:03 AM
InsneDrmr's Avatar
It could possibly be the H.U. If you brought it to best buy or circuit city...or something like that, I think they would check it out for you.
Old Nov 7, 2005 | 11:44 AM
wayman's Avatar
I forget exactly where I bought it but I'm pretty sure I bought it online.
How can it be reversed polarity if everything sounded fine for several months and then both fronts started cutting out at the same time?
It just seems to be an HU problem based on the evidence at hand. Any further thoughts folks?
Thanks.
Old Nov 7, 2005 | 12:27 PM
DR-Max's Avatar
The output section of your h/u is toast. This has happened to me before but a non-Pioneer brand.
Old Nov 7, 2005 | 12:51 PM
GodFather's Avatar
Made in Taiwan
when it's fading out, does it go staticky? if it does, then you wired it wrongly in polarity. if it just fades out clean, then it's most likely your head unit.
Old Nov 7, 2005 | 05:01 PM
wayman's Avatar
It definitely fades out clean like someone is hitting a mute button. Then it comes back for a second or two then out again. No static.
Old Nov 7, 2005 | 05:03 PM
wayman's Avatar
At this point, I prefer that it be the head unit. That's an easy fix instead of having to tear open my doors and check wiring.
Anyone have any recommendations for new head units that can play MP3's? Don't need DVD.
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
ivorton23
Sep 28, 2015 09:08 PM
