A/T Tcm Reset Help (Not how to read Tcm Codes)
Old Nov 7, 2005 | 11:05 AM
charlestek's Avatar
Hi. There are posts in the forum that duplicate what is in the Haynes manual as far as a complicated set of moving the shift lever pushing the overdrive switch and putting the ignition switch in certain positions in ORDER to "READ" the TCM CODES. HOWEVER, there is no info on how to "CLEAR "THE CODES for the tcm.
The haynes manual is not explicit on this detail.
I need this info because I am adjusting my idling speed and the FS manual says to disconnect the throttle position sensor harness, do some adjustments,
then reconnect it. Disconnecting it will put codes in the TCM that need to be erased.
Old Nov 7, 2005 | 11:10 AM
njmodi's Avatar
Do I get a tax break?
Disconnect the TPS will only set ECU codes, not TCM codes.
Old Nov 7, 2005 | 08:15 PM
charlestek's Avatar
FSM Says no
The factory manual specifically says it will set both codes.
Old Nov 8, 2005 | 07:08 AM
njmodi's Avatar
Interesting. When I unplugged my TPS to adjust the idle, I don't remember having any codes stored in the TCM (i.e I don't remember my OD light staying ON). Perhaps the TCM will clear the codes auto-magically.
Old Nov 8, 2005 | 02:45 PM
njmaxseltd's Avatar
If you only unplug it once during a single start you wount store any error codes.
The ECU needs to see an error happen more then once before it sets a code.
The transmission uses the TPS to determine shift points, but I've never heard of a TPS code being stored in the TCM?
sctludwig
Sep 1, 2022 01:32 PM
ballerchris510
Sep 23, 2015 08:46 PM
220k+ A32
Sep 22, 2015 03:08 PM
Steven Orozco
Sep 12, 2015 10:41 PM
Colossus
Sep 9, 2015 05:46 AM
