HIDs on a 96 MAX
Old Oct 12, 2000 | 10:40 AM
nismo96max
I have a set of 2000 Mercedes C500 headlight assemblies, they come with the bulb, balast, and everything I need to hook them up. My question is, how do you make an adapter for the bulb to fit my housings, I have the 97+ headlights.
Old Oct 12, 2000 | 10:55 AM
Albertt's Avatar
Not possible. The 9004 just can't support an HID system>
unless you get one of those kits. But, you lose your high beams when you get these conversions. Then, there will always be the retards that go and say "with HIDs you won't NEED highbeams". THat's a load of bull doodoo...you always need highbeams. Get a wire harness upgrade and some high wattage bulbs...this is the best thing a Maxima owner can do for better lighting at this time.
Old Oct 12, 2000 | 10:58 AM
Shingles's Avatar
The missing moderator
Re: Not possible. The 9004 just can't support an HID system>
Yep, not to mention the comeplete distruction of your beam pattern.
-Shing
Old Oct 12, 2000 | 11:00 AM
nismo96max
[QUOTE]Originally posted by Albertt
[I]unless you get one of those kits. But, you lose your high beams when you get these conversions. Then, there will always be the retards that go and say "with HIDs you won't NEED highbeams". THat's a load of bull doodoo...you always need highbeams. Get a wire harness upgrade and some high wattage bulbs...this is the best thing a Maxima owner can do for better lighting at this time.
SO WHAT DO YOU RECOMMEND? I AHVE NOKYAS RIGHT NOW, THEY ARE NICE BUT NOT BRIGHT ENOUGH, I LIKE PIAA SUPERWHITES, BUT THEY ARE JUST TOO PLAIN. HID WOULD LOOK REALLY NICE ON A MAXIMA. WHAT KIND OF CONVERSION KIT ARE YOU TALKING ABOUT? MAYBE I SHOULD CUSTOM INSTALL THE BENZ LIGHTS ON MY MAX, HAHAHA.
Old Oct 12, 2000 | 11:09 AM
97GLES's Avatar
Re: Re: Not possible. The 9004 just can't support an HID system>
[QUOTE]Originally posted by nismo96max
[I]
that's right but you can put the h i d in the max. we do them in my job. i'll ask the inst. and get back to you. i think you have to use your 9004 bulb , we do them on almost any car and they look really good.
Old Oct 13, 2000 | 04:20 AM
EZEMaxima's Avatar
headlight conversion?
Maybe you might wanna do a headlight conversion. What i mean to say is modify your hood ,fenders and possibly grill to fit the pair of mercedes headlamp assembly to your Maxima. The Honda camp has been doing that alot. I have seen a 98 Nissan 240 projector headlamps on a Honda civic. good luck!!!!
Old Oct 13, 2000 | 10:19 AM
Albertt's Avatar
Nismo96Max: Here's what you want to do >>
Go to either
http://www.autosyndicate.com/
or
http//www.carparts.com
and order the wire harness for a non-Toyota 9004 headlamp system.
Then, go to
http://www.susquehanna.com
and order up some 9004 overwattage bulbs, either 80/100Watt or 100/130Watt. They come in superwhite, regular and even riceboy blue according to your taste.
Old Oct 13, 2000 | 10:43 AM
tclee's Avatar
hum....check this site out!
http://www.xenonshop.com
they peddle the philips HID system for $620 shipped, includes everything. Phillips bulbs, ballasts, beam correction, blah, blah, blah...Looks
pretty damned good if you ask me! Check it out and pass it on to our little discussion group. and I understand these kits are totally retrofittable.
wonder if anyone has experimented with these?
rgds
-Jason
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
