reset computer
Old Oct 13, 2000 | 08:32 AM
maximadan96's Avatar
can someone tell me how to reset the computer on a 96 nissan maxima because im getting MSD ignition and i need to reset computer after i put it please help me... what do i do????
Old Oct 13, 2000 | 08:46 AM
AntGVR4's Avatar
yup
disconnect the battey for 45 min
Ant
Old Oct 13, 2000 | 08:48 AM
kajeno's Avatar
I think if you unplug your battery for a two hours, the computer will reset itself.
KAJENO
Old Oct 13, 2000 | 09:39 AM
mzmtg's Avatar
Minister of Silly Walks
It's easy
The ECU is located down in the center of the dash next to the gas pedal. Turn the key to the on position, but do not start the engine. Pop off the plastic panel just to the right of the gas pedal, it has two fasteners. That silver metal box is the ECU. There is a screw with a sticker over it that says something to the effect of "dont **** with this screw", this is the screw you will **** with. Turn the screw all the way clockwise for 2-3 seconds and then turn it all the way counter clockwise and your Check Engine light will begin to flash out the error codes. Turn the screw all the way clockwise and back two more times, waiting about 2-3 seconds at each end of its travel and the light will be reset. This worked for me.
Old Oct 13, 2000 | 11:25 AM
Daniel B. Martin's Avatar
Please elaborate on the MSD ignition you intend to install.
In most cases there is no need to reset the computer after installing a modification.
Detailed instructions for doing a Diagnostic Trouble Code readout and a computer reset are in the Chilton and Haynes manuals. You will also find that information on Steve Cutchen's excellent MaxFAQs page: http://web2.airmail.net/scutchen/max_faq/
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 23, 2015 08:46 PM
Colossus
Sep 9, 2015 05:46 AM
