Couple of Questions
Old Nov 8, 2005 | 08:46 PM
jdrvr18's Avatar
Couple of Questions
Ok question number one: I have a oil leak that i can see oil driping off of the oil pan. I thought that it was the oil pan gasket but i replaced that and its still leaking. It really only does it after it builds up presure. Most of my engine is clean and i cant see anywhere else where its coming from. Anyone know what it could be?
Now question number 2: My timing chain is rattleing when i first start it in the mornings and it doesnt stop til it gets warmed up. I was reading on other threads and most people say its the tensionor or something like that. Well i called around to the local mechanics and they said that it would probally need a new chain,guide,and tensionor and would cost around 1,000. I was wondering about how long you could drive it with it rattleing like that, or is it bad to drive it like that? Let me know...thanks
Old Nov 8, 2005 | 08:50 PM
maxihari77SE96's Avatar
Could be the oil switch. I just had that changed. Had the same problem.
Old Nov 8, 2005 | 08:54 PM
njmodi's Avatar
Do I get a tax break?
1. Most likely its just the oil pressure sending unit leaking. Its a 10 dollar part and with the correct tool, takes 5 minutes to replcae.
2. The rattle is indeed caused by a weak tensioner. If you are handy, you can replace the tensioner on your own through the access panel. This is not a trivial repair - so only attempt it if you have the skill. What weight and brand of oil are you using?
Old Nov 9, 2005 | 12:44 PM
jdrvr18's Avatar
what exactly is the oil pressure sending unit and where is it located? I am running castrol 10w30.
Old Nov 9, 2005 | 12:47 PM
njmodi's Avatar
It's located right near the oil filter - you'll see a harness plugging into it. It screws into the oil pan.
You might want to clean all that area up with some solvent (brake cleaner or something) and then you'll be able to see where the oil is leaking from better.. but that is likely the problem. Check the stickies for more information.
Old Nov 9, 2005 | 12:55 PM
NmexMAX's Avatar
dot dot dot ...
5$ at AZ.. ... It's right behind the CPS . Make sure not to try and and pull it out, it screws out actually as nj stated.
Old Nov 9, 2005 | 12:57 PM
jdrvr18's Avatar
Ok ill try to look for it later on, and what about the rattling, is it ok to drive with it like that til i can save up the money to get it fixed?
Old Nov 9, 2005 | 01:19 PM
NmexMAX's Avatar
dot dot dot ...
Mine rattles Change the tensioner and that will make it rattle a little less. Search it's on here somewhere. Donate to search though... Point beng, it wont do any harm (noise)
Old Nov 9, 2005 | 01:23 PM
jdrvr18's Avatar
i did search on here and it says its the tensioner but i just want to know if its ok driving it with it rattleing like that or not, i didnt know if the chain would wear a whole in the cover or not.
Old Nov 10, 2005 | 07:50 PM
jdrvr18's Avatar
anyone know if it will hurt or not?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Violator
Sep 9, 2015 10:14 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
jfl330
Sep 4, 2015 01:44 PM
