ok i need help from anyone with ideas
my car is barely starting each day now, i had ects codes and intake temp sensor, replaced them both no more code, but last one is absolute pressure sensor, i know where it is and it looks fine, can that effect engine starting, i dont kno, and yes my starter is fine ignition components yes , it is a sensor or something, because my car turns over and almost starts until about a minute later then it starts, so im assuming its the spark, and i checked the cam shaft sensor as well as the 2 crank sensors even tho i didnt get codes for them, even so, the car would not start at all at least mine hasnt in the past when i removed one or all 3 for testing purposes, so anyways, anyone with any ideas or clues please help, thnks
Originally Posted by utjon
If you have a code on something, you should fix it. I am not sure if it would affect that but it is entirely possible. Replace and try starting
If that doesn't work, then do some more trouble shooting.
Anyways, how do you know if your starter is good? Sounds like starter to me.
I kind of knew mine was dying (when the car did not want to start I would take my torque wrench to it and persuade it), but I still took it to Autozone to get it checked. I then bought one from them.
tarun900
19
Dec 20, 2021 06:57 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
