I replaced the 02 sensor twice but keep getting the same code!! $##%#@@)(%$
Old Nov 14, 2005 | 05:13 PM
HarrisH's Avatar
I replaced the 02 sensor about a month ago when I received the 0503 code months after replacing it with a brand new Bosch 02 sensor from Napa. Then I received the damn code again 3 weeks after replacing it with a OEM nissan! I resetted the computer and 1 week later it comes back again!!!!! I check the connector it looks good, it's on nice and tight, wtf????? This is expensive, and annoying!! HELP.
Old Nov 14, 2005 | 05:39 PM
Toolrocks's Avatar
There are at least 3 O2 sensors on your car. Are you sure you're replacing the bad one? Also, it's good to check the connector but sometimes the wire themselves are bad or broken somewhere.
Old Nov 14, 2005 | 05:46 PM
njmaxseltd's Avatar
Originally Posted by HarrisH
resetted
No such word in the english language. Didn't you have a thread up about this 2 weeks ago?
Old Nov 14, 2005 | 05:53 PM
Kevlo911's Avatar
Kevlo for President
Bad ground.
Old Nov 14, 2005 | 05:54 PM
HarrisH's Avatar
Forgive me for not scoring a 4.0 on my org term paper. Yes I did have a thread and I replied I will reset the ECU and see if it comes back. Well, it did come back.
Old Nov 14, 2005 | 05:55 PM
HarrisH's Avatar
Originally Posted by Kevlo911
Bad ground.
Bad ground? Where?
Old Nov 14, 2005 | 06:04 PM
Kevlo911's Avatar
Kevlo for President
O2 sensor ground. Reground it, tap near the sensor and run a wire to the block or batt.
Old Nov 14, 2005 | 06:15 PM
HarrisH's Avatar
Umm forgive me for sounding like an idiot. But I'm lost. The O2 sensor as far as I know is plug and play. Screw it into the exhaust mani's and plug in the connector. Where is the actual o2 sensor ground located, are there seperate grounds for all 3 or just one main one?
Old Nov 14, 2005 | 06:32 PM
Kevlo911's Avatar
Kevlo for President
I believe the ground goes to the Lower IM.
Old Nov 14, 2005 | 06:44 PM
HarrisH's Avatar
There are several engine grounding points on the car. Where does the ground on the lower IM which you are referring to track back to?
Old Nov 14, 2005 | 06:47 PM
Kevlo911's Avatar
Kevlo for President
Most of the sensors in the engine bay.
Old Nov 14, 2005 | 07:16 PM
Haibert88's Avatar
Your ECU may need to be re-programmed, the dealer will take about $90 to do that...Call and ask your Nissan dealer and tell them about the history of changing the sensors (talk to a service advisor of course)
Old Nov 14, 2005 | 08:06 PM
HarrisH's Avatar
I doubt that, if you mean re-setting it then I can do that myself within 30 seconds.
Old Nov 14, 2005 | 08:07 PM
HarrisH's Avatar
OH SH8! I think I replaced the wrong o2 in the first place. The front right is closest to the firewall DUH. I THINK I had replaced the one closest to the radiator, which according to courtesy parts is the FRONT LEFT. Can interchange the o2's to see if it's really the sensor that's bad?
Old Nov 14, 2005 | 08:08 PM
Kevlo911's Avatar
Kevlo for President
Yes, you can.
Old Nov 14, 2005 | 08:43 PM
njmodi's Avatar
Do I get a tax break?
If you look at your old thread, I believe I already suggested that you may be replacing the wrong sensor.
Old Nov 15, 2005 | 06:39 AM
nismology's Avatar
Bad ground.
What are you talking about? The o2's are grounded to the heads via the exhaust manifold and/or the grounding straps attached to the exhaust.
Old Nov 15, 2005 | 12:57 PM
Kevlo911's Avatar
Kevlo for President
Why does the FSM say to loosen and tighten the grounds on the lower IM when you are checking the O2 sensor then?
Old Nov 15, 2005 | 01:14 PM
nismology's Avatar
Not sure, but i do know these two things to be true:
1. The FSM makes no mention of a bad ground as a cause for an o2 sensor code.
2. The o2 sensor wiring harness doesn't include a ground wire. It's 2 heater wires and one signal wire. This means that the grounds that attach to the LIM have nothing to do with any o2 ground.
BTW, i just looked through the FSM and saw no instructions saying to mess with the LIM ground when checking o2's.
Old Nov 15, 2005 | 01:40 PM
Kevlo911's Avatar
Kevlo for President
EC-144 on the 97FSM. But you are right. It is two heater and one signal. Woops. Sorry for the wrong info.
mrc00l88
Jan 25, 2024 01:14 PM
AnsonJ
Jun 2, 2017 01:35 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
