is my clutch bad or what? please help me figure out whats wrong.
Old Nov 16, 2005 | 09:44 AM
loverholic's Avatar
iAMIXAM!
i really need some help with this, i've got a 96 GXE AUTO, and i do alot of hard driving, i drop my gears and shift manual till drive, lately this thing has ben happening that i cant really explain, its like my car gets stuck on the clutch the it shifts from 2nd-3rd, but only when i am accelarating at about 2000rpm or somewhere about there. its like somethingis hold me from behind, the accelaration feel like it is beeing forced. when i deep the pedal just lil more it pushes off like it is suppose to.
i dont know if its becuase i have been shifting manually or what.
what do u guys think, is it my clutch, my gear cam or what?
thankx fellas
Old Nov 16, 2005 | 09:52 AM
MrEous's Avatar
^ Jeff™
Yeah...you need to replace your clutch.
Old Nov 16, 2005 | 09:53 AM
njmaxseltd's Avatar
There is no clutch (per say) in an automatic transmission.
Sounds like your hard driving and abuse of the transmission has caused it to fail.
If you want to shift your car manually, go by a 5 speed. For now, get some quotes on a tranny rebuild or try and find a used one, yours is most likely shot.
Old Nov 16, 2005 | 10:35 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
An automatic tranny is not designed to be shifted manually.
Old Nov 16, 2005 | 10:36 AM
loverholic's Avatar
iAMIXAM!
thanks guys. well i really wanted a 5sp but, it was at a time that my other was down and i couldnt find a 5sp so i took this hoping to trade it in for an 03 someday, but the 06 go tme looked. but back to my tranny, so u r positive its goingout? cause i stopped all this manual shifting and it doesnt so it as much now, it does it just a lil. i still drive hard when i get teased btu i keep it in drive, i got ona shortram masflow ontake so my take aint that bad
Old Nov 16, 2005 | 10:41 AM
kormax97
Wh@T?? D@ who??
Please report yourself in to 1-800-I-SHOT-MY-TRANNY.
Old Nov 16, 2005 | 12:46 PM
loverholic's Avatar
iAMIXAM!
so do u mean its gone for good and its just a matter of time till it dies?
Old Nov 16, 2005 | 12:50 PM
Dan's Avatar
Dan
you might be able to extend the life with a fluid change but it will eventually wear it out. Hard driving doesn't help you
Old Nov 16, 2005 | 01:53 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
might as well do your 5spd swap now
Old Nov 16, 2005 | 09:24 PM
loverholic's Avatar
iAMIXAM!
about how much will that cost me?
Old Nov 17, 2005 | 06:52 AM
nismos14's Avatar
§è~® f®ÈÄk
Wow:
1) Learn how to type properly. If you can't understand what you wrote, no one else can either, re-read before you post!
2) None of us can really tell you what exactly is wrong. We do not drive your car we do not feel the symptoms you do.
3) Most likely someone in your area who is MORE familiar with maxima's than you should look at it.
4) There is a diagnostic procedure for the automatic transmission if I'm not mistaken, get a service manual and see what you can find out.
Old Nov 17, 2005 | 06:57 AM
ColdSHO's Avatar
sawdust mod!
then when that fails 5spd swap.
Old Nov 17, 2005 | 07:05 AM
tavarish's Avatar
fwd gone rwd cr00
oh boy.....clutch and gear cam....
http://auto.howstuffworks.com/automa...ansmission.htm
please, learn something.
Old Nov 17, 2005 | 08:29 AM
loverholic's Avatar
iAMIXAM!
i'm going to change my tranny fluid today and see if that helps, because it has been doing a lil better since i stoped all of that manual shifting.
Old Nov 17, 2005 | 08:37 AM
loverholic's Avatar
iAMIXAM!
whats 'sawdust mod' ?
and where can i get a service manual?
Old Nov 17, 2005 | 08:40 AM
kormax97
don't take everything litterally.
you can get a service manual probably on the classifieds section.
Old Nov 17, 2005 | 09:34 AM
ColdSHO's Avatar
the sawdust mod is putitng sawdust in ur trans fluid to make it thicker so it doesnt slip, its used by shady used car lots to temporyly fix a car to make it sem like tis not broken.Dont do it, its a really bad thing to do. sadly i think its time for a rebuild or swap. id say hit up some junkyards for used parts. theres lots by me with full trans. sure theres soem by u as well
Old Nov 17, 2005 | 01:33 PM
loverholic's Avatar
iAMIXAM!
lol, thats funny.
i will do that, i know of this junkyard real close to me where they got 3 97 maxs, but let me ask this, can the 5 gens tranny work with my 96 max?
BkGreen97
Apr 2, 2016 05:47 AM
Max139617
Sep 20, 2015 07:25 PM
220k+ A32
Sep 11, 2015 02:18 AM
trungg86
Sep 4, 2015 04:58 AM
