Fuel Cut off during deacceleration in manual ----> converted?
Old Nov 18, 2005 | 11:23 AM
scrhale's Avatar
I read somewhere that manuals have a fuel cut off while your foot is off the petal thus maximizing fuel economy. If you convert your car, do you get the advantages? If not, what else do you need that is not in the 5 Spd swap list in All-Motor?
Old Nov 18, 2005 | 11:31 AM
MaximaSE96's Avatar
Maxima Owner
yea its called not pressing the accelerator
Old Nov 18, 2005 | 11:37 AM
scrhale's Avatar
Wow that is pretty simple, call this thread useless. Mods can lock if you want.
Old Nov 18, 2005 | 11:43 AM
MaximaSE96's Avatar
Maxima Owner
i was joking.....but i have never heard of an actual electronic fuel cut when u let off the pedal......it might be true with the drive by wire cars
Old Nov 18, 2005 | 12:04 PM
scrhale's Avatar
http://forums.maxima.org/showthread....uel+cut+manual
look for fuel cut mode ... that is what i was referring to
Old Nov 18, 2005 | 12:37 PM
Mxrider52's Avatar
I support for what?
I kinda agree when I let off the throttle it coasts but when I press the gas it kinda jumps
Old Nov 18, 2005 | 01:21 PM
MorpheusZero's Avatar
Are you referring to this? http://forums.maxima.org/showpost.ph...4&postcount=19
That has nothing to do with your transmission, it's a feature of your engine. There are no differences between the VQ30DE engines coupled with an auto or manual transmission. The FPR is identical on both engines.
This has nothing to do with the FPR, it's just that you're not a very smooth driver yet. When you press quickly on the gas at a low rpm (especially in a high gear), you quickly load up your drivetrain and then you get the "lurching" effect, which will continue if you quickly let off the gas, unloading your drivetrain. It's a fact of life for manual transmissions, you've either got to get used to it or learn to drive more smoothly.
Old Nov 18, 2005 | 01:25 PM
nismology's Avatar
There's a fuel cut-off with you're foot off of the accelerator regardless of the transmission type. This is provided you're in gear above around 1300 RPM. Below that and the ECU goes back into open-loop idle fuel trim.
Old Nov 18, 2005 | 11:42 PM
ThurzNite's Avatar
Jae
Old Nov 19, 2005 | 06:36 AM
tomservo291's Avatar
not necessarily true, is that from nissan?
i started this thread in the general section before and it attracted a WEALTH of information.... check it out:
http://forums.maxima.org/showthread.php?t=427015
some really interesting points raised and talked about there.
Old Nov 19, 2005 | 07:55 AM
nismology's Avatar
Not necessarily true?? That info is taken directly from the FSM.
I posted in that thread and the general consensus was that there was a fuel cut during deceleration until around 1300 RPM when the ECU goes into idle fuel trim.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
