It goes creaaaakkk, when I turn the wheel while stopped to the far left
Old Nov 18, 2005 | 12:55 PM
HarrisH's Avatar
When I turn the steering wheel all the way to the far left when stopped and not in gear. I can hear it groaning/creaking only when it's turned to the far left all the way. The power steering fluid level is good. What can it be? No driveability issues though.
Old Nov 18, 2005 | 01:06 PM
Fr33way™'s Avatar
Wild for Width
What shape are your CV's in?
If it wasn't obvious I would try to have someone turn the wheel while I was under the car. You may be able to check off many possible causes that way.
Old Nov 18, 2005 | 01:59 PM
HarrisH's Avatar
Axle is pretty much brand new... the strut boot the rubber piece is shot to all hell, lol but I doubt it does much. Also with the car jacked up and me turning the wheel the noise disappears it's only when the tire has a load on it. So I think it might be strut mount related what do you guys think?
Old Nov 29, 2005 | 05:31 PM
jian622's Avatar
Axles.......
Old Nov 29, 2005 | 05:36 PM
njmodi's Avatar
Do I get a tax break?
Could also be a bad strut bearing...
Old Nov 29, 2005 | 05:42 PM
HondaKiller718's Avatar
1) if the rubber covering that protects the axel is shot then its the axel, 2) if the rubber covering that protects the lower control arm ball bearing is shot you need to replace bearing or buy new control arm from http://www.importspecialistsofamerica.com about 50 bucks. 3) could also be the wheel bearings and hub- do a search on this you will find alot of info.
May the force be with you.
alixc
Aug 11, 2020 01:48 PM
trasmadean
Feb 1, 2017 08:20 PM
official_style
Aug 29, 2015 10:10 AM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
