Gasoline smell in car when heater is turned on
Old Nov 19, 2005 | 07:17 AM
boostaddict's Avatar
All fuel lines are tight and no leaks in Injectors. Anyone had this problem and how can I fix it. I only get the gas smell when I turn on the heater otherwise no smell and have no problems with the fuel filter. Thanks.
Old Nov 19, 2005 | 07:57 AM
Mxrider52's Avatar
I support for what?
If you can smell the gas pretty strong I would check your fuel filter
Old Nov 19, 2005 | 12:37 PM
isawyou's Avatar
This happened to me right after I bought the car last January (the temperature then was about -40)
There was a short (3"-4") length of fuel hose in the engine compartment with clamps on both ends that apparently became a little loose and leaked gasoline. With the hood open, the hose is easy to see right on top of everything. It is between the intake manifold and the air filter, right below the throttle and cruise control cables (near the center of the engine compartment, slightly to the driver's side). Check that out. You may need a new hose or to simply re-tighten the clamps. If that hose is leaking, you will be able to see drops of gasoline dripping when the engine is running.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
