problem found. can i fix this myself?
Old Nov 21, 2005 | 02:54 PM
VIP Maxima
i posted another thread about how my car's RPM all of a sudden would drop and choke on me. i think i found the problem today. so there is a plug that goes into the MAF sensor, there are three wires that connect to the plug. one of them is yellow, the yellow plastic wrapped around the wire inside has been slashed after being rubbed against the sensor itself. the wire inside is almost cut all the way as well. this means out of the 3 wires, 2 of them are connected and one is almost all the way slashed. how can i fix this? should i get another plug, cut my original wires in half and connect them to the new plug or wut? is this whats causing my car to choke?
darn, i need the car for tomorrow ! stupid little problems
Old Nov 21, 2005 | 03:11 PM
Mxrider52's Avatar
I support for what?
2 wire screw caps cut the wire add some extra wire add a wire cap and connect the other side with a wire cap and wrap in black tape. I am unsure the name of the caps but they connect to wires together all I know. Seem to me that will work till you figure something out
kormax97
i don't see why not. if you think it's the plug, not the maf itself, try changing the plug only but don't ghetto wrap it with just electrical tape.
Old Nov 21, 2005 | 03:15 PM
NmexMAX's Avatar
dot dot dot ...
Old Nov 21, 2005 | 03:16 PM
VIP Maxima
well, right now the plug going into the maf has one of its wires slashed, so thats most likely the problem. im going to local junk yard to buy another plug. :rollseyes:
Old Nov 21, 2005 | 03:47 PM
wannaboostbad's Avatar
HOpefully u got enough wire where u can strip it leavin some open wire get a butt connector (preferably the one with soder inside of it) and connect the 2 wires u cut and get a lighter and melt the connector till the soder melts...
ex:
M
A----[cut here to expose wire] {butt connector}---remainder of wire to ECU
F
Old Nov 21, 2005 | 05:38 PM
VIP Maxima
ex:
M
F
thats what i did. i didnt know we had to melt the soldier. do i melt it with the plastic protecting it or take off the plastic? waiting for my intake filter to dry so i can put everything back on. cleaned TB as well........
ill post an update in an hour or two.
Old Nov 21, 2005 | 08:51 PM
konak85's Avatar
You were the one that was ranting about how Nissan sucked. Kinda true but whatever. lol, Frustration does that to you. Glad to see you found the problem.
Old Nov 21, 2005 | 09:36 PM
the_3d_man's Avatar
just use a butt clamp...
you can get them from walmart. you crimp the wire ends into it.
Old Nov 21, 2005 | 10:04 PM
VIP Maxima
i fixed it. hopefully thats what was causing this. and yah im frustrated. cuz of a ****in wire thats barely as thick as a string of hair, the whole damn car starts actin funny and dies on you then it wastes your time. makin trips to junkyard and random bs.
im tired of somethin going out every month. whats nexT?
Old Nov 21, 2005 | 10:46 PM
Supermax95's Avatar
what do you mean choking...when you are driving and hit the clutch do the rpms drop really low and almost(or do) turn on...
Old Nov 22, 2005 | 01:01 AM
santiagomax97
I need help with the high pressure power steering hose can i install thise my self some help please! its burning my manifold.
Mar 12, 2020 12:06 AM
thenewguyy
Sep 12, 2015 11:12 AM
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
